TBI 5.7 350 Timing?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by badfish4tail, Nov 14, 2005.
  1. badfish4tail
    badfish4tail 1/2 ton status
    Mar 1, 2005
    1,684
    Long Beach
    Hey hopefully someone can help me out with this. I am working on my 1991 Blazer which has a 5.7 350 with TBI. I was wondering what the timing needs to be set at and anyone know were to look for the wire to unplug. Had a buddy (onlychevy6) check the timing with his gun and showed my timing being at 12*. Thanks for any help you can offer...
    Ialso posted this in the garage.
  2. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    Next to the firewall bulkhead connector, tan wire with a brown strip. Or it could be under the dash.
  3. kram
    kram Registered Member
    May 29, 2005
    54
    Edison n.j.
    88 is zero, large indent on pointer.
  4. sweetk30
    Nov 1, 2004
    25,528
    527
    horseheads , ny 14845
    both are correct. tbi is zero. with wire unpluged before start up. and when done shut off and replug wire in and fire and make sure check engine light goes out.
  5. trikstark5
    trikstark5 1/2 ton status
    Feb 17, 2004
    169
    usa
    Disconnect the tan wire by the firewall with the truck not running. Start the truck, and set the timing to 0*. Shut the truck off and rehook up tan wire. That should pretty much do it.
