TBI acting like its loading up at low speeds(idling around the woods)
Discussion in 'The Garage' started by scoutillac, Apr 8, 2004.
  1. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    When I am out wheelin or just idling through the wood lookin' for a helpless meal on four legs my burb starts kind of surging like when a carb loads up. How do I fix/prevent this problem? /forums/images/graemlins/dunno.gif
    Damn I'm full of questions today.
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Could be EGR, vacuum leak, fuel pressure, IAC, TPS, ....any codes?
  3. scoutillac
    Feb 24, 2004
    423
    Spokane, Wa.
    No codes. Timing is set to specks and I believe I have all the vac leaks fixed. But there are so many lines. If I spray carb cleaner under the air cleaner it doesn't die out. That is how I was told to find a vac leak.
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Maby check the TB base gasket. They go bad and cause vacume leaks.
    BTW Spraying carb cleaner to find vacume leaks is a good way to start a fire.Bad plug wire=spark=BOOM! Water in a spray bottle works just as good and is a lot safer. RPMs drop when it sucks water in thru a vacume leak.
  5. scoutillac
    Feb 24, 2004
    423
    Spokane, Wa.
    Thanks for the safety advice /forums/images/graemlins/waytogo.gif
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Don't overlook the simple stuff as well. A distributor cap that has outlived its usefulness can cause crossfiring that will first be most noticeable at low RPM. /forums/images/graemlins/thumb.gif
  7. scoutillac
    Feb 24, 2004
    423
    Spokane, Wa.
    It has been awhile since I changed the cap and rotor. Come to think of it I really need to get off my butt and tune it up thoroughly. /forums/images/graemlins/thinking.gif
