TBI Adapter plate - Made it today on break! pics
Discussion in 'The Garage' started by bigburban383, Jan 5, 2004.
  1. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    I made this today on break. Well, HillBilly programmed the Bridgeport to cut the ports, but I did everything else /forums/images/graemlins/thumb.gif
    This is the top, its aluminum so I helicoiled the TBI threads[​IMG]
    Notice the chamfer on the ports, that well help prevent the venturi effect[​IMG]
    Fully assembled
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Very nice, How thick is the plate?
  3. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Its only 1/2 inch. It was free so im not complaining, but I was searching for the 3/4 inch. It would then double as a TBI spacer and give me some more torque. 1/2 inch will do anyways.
  4. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    What intake is that. Is it a single plane ?. Looks like an e-bock performer dual plane to me. I have heard of people doing this on a dual planes and have had some issues.
    Looks like you put the holes right in the middle of the dual plane intake. I am also making one for my Vortec intake e-brock RPM manifold which is also a dual plane intake. I think I might set the holes back a little and mill out the center divider on my intake to prevent starvation. I have a drawing already all I need is some time on my mill to get it done. I wish I had a CNC mill..hehehe.
    T.J.
    www.tjsperformance.com
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Painless wiring has one available that I was going to buy. I honestly hope that works out for me, I don't want to drill an intake or use the centerbolt heads.
  6. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    T.J.
    Yes its a edlebrock performer dual plane. The TBI bolt holes are acctually off set so the bolts dont hit the center divider. So what problems did people have? Was it a engine running issue or was it a design issue?
  7. Grim-Reaper
    7,385
    Atlanta
    Ohhh...SHould I not use my 87-89 454 Preheat adaptor that is a direct bolt on for a GM Spread bore used from the 60's to the late 80's?
    hehehe I don't think anybody knows about this little Gem.
    Nice machine work though.
  8. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    So what is this mystery Preheat adaptor that your talking about?? Do you have a part # for it? Pic??
  9. Grim-Reaper
    7,385
    Atlanta
    I need to double check the part number. Didn't realize it didn't come out clear. I think its 10086789.
    The TBI unit is LARGER then a 350 TBI My understanding is this was only used on 87-89 N code 454's. In 90 the 454 went to a simular style intake like a SBC had with the built in boss for the 2bbl TBI.
    The adaptor was plumbed into the heater hose to preheat in the cold. I have a 88 454 sub with the same set up and never had a issue with it freeszing up without it hooked up as long as I was running a stock air cleaner with preheat off the manifold.
    You must also use the factory gasket (not pictured) $5 from the dealer. It will work fine on a Spread bore intake. /forums/images/graemlins/thinking.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wonder if it'd seal on an Edelbrock intake.
  11. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    T.J.
    People are having running and driveability issues.
    T.J.
  12. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Hey Travis, if ya need one of those, I just happen to have one "in stock". /forums/images/graemlins/wink.gif
  13. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    The 454 one if so how much. Just got all the tbi stuff and need an adapter for mine.
    By the way nice looking adapter
  14. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    T.J.
    T.J.
    That really sucks. Do you think a 454 TBI unit could remedy that problem?
  15. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I have Holley Pro-Jection on an Edelbrock intake with similar Holley adaptor as the one you built. I do not have driveability issues with mine.
  16. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, it's from an '89 or '90 TBI 454. $20 plus shipping and it's yours. /forums/images/graemlins/cool.gif
  17. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    Bigburb,
    Have you used it yet. If so how is it. Also do you happen to have a dimensional drawing of that. I have a drawing of a carb adapter all I need are the rise/run dimensions of the bolt spacing for the TBI and the spacing and size of the holes. If not I just need to spend some time with a TBI and a caliper.
    T.J.
  18. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Bigburb,
    T.J.
    I'll tell ya how I did it. Cut a piece of square cardboard put a tiny bit of oil around the bolt holes on the intake and set the cardboard on that. That left a oil stain with the hole in the middle and I marketed it. The I took the TBI gasket and centered it on the cardboard, marked the holes and the ports. Then you reference the cardboard to your plate. I cut the intake holes bigger to compensate for error, but make sure the TBI screw holes are perfect.
  19. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Several companies make TBI to Carb manifold adapters. Holley and TurboCity just to name a few.
  20. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    I know for 50$ or more but I like to save where I can.
    Harry I'll pm ya.
