TBI Alternator on non TBI truck?
Discussion in 'The Garage' started by sled_dog, Aug 20, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Will an alternator from a 91 Blazer fit my 84? I mean like since hte pulleys turn the other way will it work? The 91s had the 105Amp alternator and I want to replace my K5s alternator might as well go bigger. Only things on that truck that haven't been replaced/broken, are the alternator and starter and I'm gonna strike before it happens and replace them.
  2. 89BlazerK5
    89BlazerK5 1/2 ton status
    Aug 24, 2002
    134
    it doesnt have anything to do with the TBI. the Serpintene pully system is what is different. and, i'm really not sure if it will work. /forums/images/graemlins/confused.gif
  3. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    I had one rebuilt...and had the cases clocked different so i could use it as a trail spare in my 79...just needed an adapter harness to mate to the older wiring....other than that i worked with no problems.
    DW
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    you are correct but there were no serpentine carburated rigs as far as i know
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Even on serp belt set-ups, the alternator runs off the inside of the belt, so the rotation is the same as the older V belt alts. The water pump runs off the outside of the belt on a GM truck serp. set-up, so it turns backward. The pulleys are obviously different.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    oh I didn't even think about that, thanks.
  7. K5 NUTT
    1,611
    yes...there were no serp belt setup's in 79...i was just saying i run a 87 up alt that has the case clocked to work in a older rig with an adapter plug to finish it off...course trux weren't tbi'd in 79 but mine is...lol... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
