tbi buildup cams chips ect.......
Discussion in 'The Garage' started by highrider_44s, May 30, 2004.
  1. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    thinking of building a 350 TBI for my brother but need info on some combos
    how much cam can you put in with out changing the chip
    if a chip upgrade is needed what chip would be recomended and injectors are the stock one's up to par
    /forums/images/graemlins/thinking.gif
    don't know much about injection systems so any info would really help /forums/images/graemlins/thumb.gif
  2. fwdjunky
    fwdjunky 1/2 ton status
    Oct 12, 2003
    499
    Maricopa, AZ
    Probably the best advice I can give is to call the tech lines of the companies that make tbi compatible cams (at one time I was looking into this and knew who they were, now I can't remember) and then talk to a custom chip dealer like turbo city and see what they say. When I was considering a performance rebuild of a tbi 454 I had I called several and they are all more than happy to help. I think Edlebrock sells a whole "system", cam, intake, exhaust, all set to work together with a tbi unit. I've never been a big Edlebrock fan, but that might be worth a look. Hope that helps. Rich.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If it is in the budget, Bullet/Derf00 are having good luck with the Edelbrock MPFI kit. If you ask me that sounds like a real good idea, although pricey.
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Crane, Comp, both make cams good cams for TBI. Keep the lift under .480 and the duration 212 @ .050 or under, lobe seperation 112 and the stock chip will be happy.
    Stock injectors can feed enough fuel for around 280+ - HP. You will need an adjustable fuel pressure regulator.
    Go here and read:GM TBI Tuning
    Read all the blue links on the right side of the page. Lots of good info there on building TBIs. Good info on what you can and cant do. They also sell good chips and performance mods for TBI.
    Have you also considered getting better flowing heads?
  5. highrider_44s
    Mar 28, 2004
    392
    southern B.C.
    not to sure on what he really wants yet or how much money he has for it /forums/images/graemlins/dunno.gif
    but i know he has a 305 in there that's burning oil faster than he can put it in /forums/images/graemlins/confused.gif the heads on that just had a valve job and maby some other work not sure
    i know some of the older 305 had smaller combustion chambers i think to up the compression to make up for the lack of cubic inches /forums/images/graemlins/thinking.gif
    but i don't know the specs on the tbi heads but we were thinking about looking into putting the 305 heads on.
    any thoughts /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  6. Supergas
    Supergas 1/2 ton status
    Oct 17, 2001
    161
    Texas Coast
    You might look at the LO5 GM crate engine. It is a direct replacement model 350 that can be had for around $1200.00. Then you can change the cam & get right at 270 HP with little or no TBI adjustments. It might still be advantageous to get some one like Fuel Injection Specialities www.fuelinjectionspecialities.com to shed some light on this subject. If you call them, talk to Vince, he is the magician. This engine is a brand new truck TBI engine with GM warranty...
    I currently have a stock 95 TBI engine from a Sub in my 71, & am going to upgrade it to Vortec Heads this winter. This will give me around 310 HP with approximately 420 Lb/Ft Torque at 3300 RPM. Remember with a TBI, you do not need a lot of fuel pressure, but constant flow @ 9-15 PSI.
    Hope this helps a little...
    BTW, once you use the TBI, you will never look at a carb again.
    Supergas /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif
  7. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    As someone above said, call the cam companies. They've done the dyno tests to know what works. I have a Comp cam they recommended in my otherwise stock TBI 350. It does run better than the average TBI 350, and there are no bad side effects. /forums/images/graemlins/waytogo.gif
  8. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    I have 305 heads on my 388, I don't think my computer likes them. I have no power after 3500 RPMs. I have to run 93+ octane fuel.
  9. dyeager535
    26,979
    You ever hooked a scanner up to it? I'm betting your knock sensor retards timing like crazy because of those heads.
