TBI cam help.
Discussion in 'The Garage' started by chevyjeff, Mar 8, 2004.
  1. chevyjeff
    chevyjeff 1/2 ton status
    Dec 10, 2003
    118
    WYLIE TEXAS
    Has anyone had any good or bad experience with this cam. Comp Cam pt# 12-249-4. Its described as great in stock throttle body or crossfire. I am planning on running it in my 350 build up using 9.3 compression, edelbrock tbi perfomer intake manifold, stock exhaust manifolds and stock computer. It will be used in my full size blazer so low end and torque is all I am after with this combo.
    Here are the cam specs as listed on the spec sheet
    Part Number 12-249-4
    Engine 1955-1998 Chevrolet
    262ci-400ci
    8cyl.
    Grind Number CS XE249H-12
    Description
    ________________________________________
    Intake Exhaust
    Valve Adjustment 0 0
    Gross Valve Lift 0.434 0.444
    Duration At 0.006 Tappet Lift 249 260
    Valve Timing At 0.006
    Open Close
    Intake 16 52
    Exhaust 66 14
    These Specs Are For The Cam Installed At 108 Intake CL
    Intake Exhaust
    Duration At 0.05 206 212
    Lobe Lift 0.289 0.296
    Lobe Separation 112
  2. bleedchevy
    bleedchevy Registered Member
    Nov 4, 2003
    54
    Oakley, MI
    thats the same cam im running, I like it over stock. youll notice the differnce when it is fully broken in
  3. chevyjeff
    Dec 10, 2003
    118
    WYLIE TEXAS
    /forums/images/graemlins/thumb.gif did you modify your throttle body and or the computer to get it to run correctly?
  4. bleedchevy
    Nov 4, 2003
    54
    Oakley, MI
    i didnt change anything since they said i didnt have to, but i figure if you do a custom chip, and a larger thortal body you would be able to take the cam to its full potential
  5. chevyjeff
    Dec 10, 2003
    118
    WYLIE TEXAS
    Cool! thats what I needed to hear. I will likely mod the tbi at later date but sure dont want to swap cams after the motor is in and have a cluster on my hands!
  6. chevyjeff
    Dec 10, 2003
    118
    WYLIE TEXAS
  7. blazingboy
    blazingboy 1/2 ton status
    Dec 2, 2001
    120
    Georgia
    If I go with the same cam on my 87 with vortec heads and edelbrock performer intake, headers and the Turbo City upgrade for the Vortec heads how much hp and torque would I be putting out or would it be worth it.
  8. bleedchevy
    Nov 4, 2003
    54
    Oakley, MI
    the best thing to do is call comp cam or any cam manufactur you prefer and tell a tech what you have and they will set you up the guys at comp cams were friendly and answerd all my questions
