TBI Cam or Manifold?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Aug 10, 2004.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Slowly doing some work to my engine, trying to make it more... peppy. Anyway, I've done the throttle body spacer and the injector spacer, getting ready to add some Hooker headers, Eastern Tru-Performance cats and MagnaFlow 4x9 Mufflers. At the same time I get my exhaust redone I want to add either a new intake manifold or cam. I'm looking to spend sub $200. Which would be most beneficial to a stock 350 with 135k? I have heard adding a new cam on an engine with this high of mileage could cause you to spin a bearing, any truth to this? I know the manifold is easier to install, but I'm willing to do either.
  2. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    it would be easier to do both at the same time since you have to take the manifold off for both installations. i would say that the cam would warrant more power especially with the other mods you have adn plan to do. look on ebay for some used manifolds adn go for the cam. so you won't have to install adn reinstall your manifold. good luck.
  3. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    I think your money would be better spent on a set of good heads. Then later on when you put a cam in and intake you'll really feel the power. If you do the cam and intake you wont be able to get full benefit and wont be able to get all the air and fuel in efficiently. I would say manifold if you can only afford one at a time. Then you could save up for cams and heads.
    Later
  4. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Heads are deffinitely out of the question, when I step up the heads it will be in a few years. /forums/images/graemlins/doah.gif
    I'm thinking intake as well as I can always resell it later when I go to different heads (if I decide to do the vortec heads like my plans).
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    If you plan on doign vortec heads, then I would just wait. I wouldn't put a new cam in an older engine like that. Plus when you do a cam, it is best to go with new lifters, pushrods, rockers, etc. And that may put you over your $200 limit. Just wait, save and do the heads, cam, intake and a rebuild all at the same time.
