TBI - Carb... which sending unit to get.
Discussion in 'The Garage' started by dodgedude99, Apr 22, 2005.
  1. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    im converting my '88 k5 from a TBI 350, to a GM 454 HO with a carb.
    since there only needs to be a feed line, what can i do about the sending unit, being that the TBI unit has like 3 or 4 lines.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    You can use the same sending unit over but you will need to remove the fuel pump and make some kind of hose to take its place and then just plug the unused return line fitting.
  3. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    can anyone else chime in for ideas also?
  4. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    get a pressure regulator and plum it in line and have a electric pump feed carb . easy to do and no drop the tank.
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If you use the stock in tank pump you must get a regulator with a return line. If you just use a basic fuel pressure regulator without a return it wil ruin the pump in a short time. The pump has to circulate fuel to keep it cool. It will burn out in a short time if you dead head it. You can get regulators with a return from Summit and Jegs
  6. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    no in tank pump.
    im running a Holley 110gph mechanical pump.
