TBI chips--ever heard of these guys? ANYBODY???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88K5Jimmy, Jan 21, 2003.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    tbi chips
    I think I will email the guy and ask him some questions about those chips. Anybody had any bad experiences with aftermarket chips?
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Re: TBI chips--ever heard of these guys?
    Ive seen him recomended at www.thirdgen.org I think he does custom chips too.
  3. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    I emailed the guy a couple times and this is what i got back:
    > These are the specs on my truck:
    > 88 fullsize GMC Jimmy
    > 350 TBI
    > 700-R4
    > 3.08 gears
    > 108,000 miles
    > Here are my questions about your chips:
    > What are the specs/gains of installing a chip?
    > What warranty/guarantee do you offer?
    > Do you manufacture these chips or where do you get them?
    > What is the life of your chips?
    > Do you have to run higher octane gas?
    > Are there any gas mileage increases/decreases?
    > Have you had any problems/returns with your chips?
    > Also, do you have any recommendations for a type of chip to install?
    > Thanks
    > Ross
    Typical gain is 15-20hp for a mere $30 investment. I offer a satisfaction guaranteed or full refund.
    I do manufacture these chips and have specialized in TBI systems for the past few years. The chips really don't wear out. If you buy a new computer for your truck, you must reuse your old prom. The only way they die is due to physical or electrical damage. You can either run high octane and stock 195* thermostat or reg gas and 160-180* thermostat. Gas mileage pretty much stays the same unless you keep your foot in it all the time. Yes there have been returns for one reason or another. I have sold a few hundred chips and have had less than a dozen returns.
    Brian
    What do you guys think?
  4. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Anybody have any thoughts, suggestions, info about chips period? Would this be a worthwhile upgrade on my daily-driver stock K5?
  5. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    Sounds great I'm going to get one from him!
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, he's telling you it doesn't affect gas mileage, but I'm sure it will. What those custom burned chips do is 1) tell the computer to dump in more fuel and 2) advance the timing about 4 degrees (hence the higher octane comment - to prevent detonation). So, if you're not worried about spending more money on gas, more often - than I say go for it. /forums/images/graemlins/smirk.gif
  7. dyeager535
    26,978
    Well, lets see.
    Say you go with the chip, and it requires more octane. Say 91 to be safe, and you can easily run on 87 now.
    Thats *only* $6 PER fill up with a 30 gallon tank. (figure $.20 more/gallon from 87 to 91 in most cases) That adds up quick for "only" a $30 investment. Of course, if mileage goes up to compensate, great, but I REALLY doubt that you'll see a $.20/gallon increase in mileage.
    Sounds to me like its mainly timing advance. If you have to emissions test, you may be running the ragged edge of passing with a chip like that.
  8. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
    Check out this thread that was discussed not too long ago.
    computer chips
