TBI, computer, and transmission swap questions.
Discussion in '1992-Present Chevy & GMC models' started by ugly_blazer, Apr 15, 2005.
  1. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Ok guys, I have a 1989 C1500 with a 5.7 TBI motor and a 700R4 transmission. The transmission is bad. If I put a TH350 in place of the 700R4, will the engine still run right without the wires hooked up to the 700R4? Like the VSS? I know the speedo probably won't work, but that's ok. I just need to know if the engine will still run right with the Th350 or if it needs some transmission input into the computer?
    Thanks.
  2. ugly_blazer
    Apr 12, 2004
    1,214
  3. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    yep mine ran fine. just couldnt get the speedo senson hooked upto easy. but some playing will get it for ya.
  4. dyeager535
    26,979
    If the VSS is mounted in the tailshaft of the trans, then no it won't be right.
    Check some posts about VSS in the garage.
  5. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    You can have a new chip burned to eliminate the VSS, but it will also disable some emmision controls like EGR, and may affect drivability to some extent. Second option would be to add an inline VSS to the cable output of the TH350. Check with www.jagsthatrun.com for that type of VSS.
