TBI dos and don't ?
Discussion in 'The Garage' started by clarkjw24, Oct 18, 2004.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    TBI dos and don\'t ?
    I've got an 87 tbi truck. The motor is blown but the injection stuff is still good. I want to put this in my 84' K5. However I recently built my current motor and I want to know what I can do for performance and simplicity. I've currently got an eldobrock Air Gap intake and a large cam. Is there anyway to keep this stuff or will I need to go with a new cam and use the tbi intake. I know holley makes thier commander kit and it will only bolt to a four barrel intake. Does anyone sell these spacers or adaptors? Also with tbi can I get the comp chip burnt to my specs?
  2. Wingnutt
    Wingnutt 1/2 ton status
    Feb 20, 2000
    324
    NOVA
    Re: TBI dos and don\'t ?
    Don't know about the rest, but you will have no chioce but to have a custom chip burnt. Depending on the cam, it may, or may not work. If someone says that they can burn you a chip just from the information that you send them....run away fast! To burn a chip for a radical cam take many hours of data logging and analyzing it to make small changes, then repeating the process over and over until you get it right. OR you can pay somebody to get the chip close enough to get the engine started and running then do your own datalogging and learn how to burn the chip yourself. That way, after you gain the knowledge, you can make the chip perfect for YOUR engine. Here's a few links to take a peek at.
    http://www.thirdgen.org/
    http://www.tbichips.com/
    http://winaldl.joby.se/
    http://diy-efi.org/diy_efi.html
    http://www.efitune.com/forum/
    http://prominator.homeip.net/
    http://misterbill.homeip.net/aboutprominator.asp
    http://www.moates.net/
    Edited to add:
    IMHO those race track goodies (ie. the intake and cam) will end up disapointing you on the trail. High RPM screamers make wonderful HP numbers, but are hate to lug along while creaping along a tight trail or easing up a long uphill pull. Not trying to tell ya how to build yer rig, just trying to get your to see the real world applications of yer combination, great for the track, but again, IMHO lousy on the trail.
  3. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Thanks for the sites. Anyone else?
  4. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Will this work? [​IMG]
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Well just cause it has a "large" cam in it, doesn't mean it wont run with a TBI.. I am running a 383 with a "large" cam and the stock TBI system. Sure it doesn't run like it should, but it runs fine.
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Isnt it MAP? With the cam the computer will think its under a load while idling and run rich. you should get a new prom burnt.
  7. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    That adapter wont work, but holley sells one that does.
    Dan
  8. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Dan
    Please point me in the direction to find the holley that will work. Also does my intake have to be egr?
  9. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
