tbi dumping to much fuel in my 383
Discussion in 'The Injection Section' started by 91GMCSuburban, Feb 7, 2007.
  1. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    Just got my built 383 in my truck and it is dumping to much fuel and fouling out the plugs. I haven't put the custom chip in it, but I also have not driven it, just start it to move it. What do you need to know to help me out?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Does it have a wicked cam? That would totally freak out the MAP sensor.
  3. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
    it is hot for TBI standards. What should I do?
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Presumably you've upped the fuel pressure in anticipation of the new chip and larger cubes. This would overload the injectors, especially at idle as you've altered the base pulse width to compensate. If you're not doing your own tuning you'll have to wait 'till you get your new chip and just hope whoever is burning for you gets it pretty close.
    If you haven't altered FP then check you've not trapped the return line. If it's doing it from cold, when the ecu is in open loop I don't 'think' it could be the cams fault as the VE tables are preset with no learn.
  5. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
    I did up the FP and added bigger injectors, but had way too much fuel and couldn't get it timed. Replaced the fuel pod with the original injectors and stock FP regulator, got it timed, and it is still dumping too much fuel. And yes, this is from cold; it has never reached temp.
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Look for leaks around the injector housing and put a strobe light on the spray pattern at idle and see if you're getting a 'spray' or lots of big drops too.
    It would be worth check the true FP too. If you're fouling plugs you're running REALLY rich and it's going to kill your bores.
  7. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
    Is it possible it is the Throttle body itself? I have a bored out TB unit that is untested.
  8. dyeager535
    26,979
    I thought there were stories of the throttle bodies actually having been bored all the way through to internal passages at some point, may have been on this board or thirdgen.org.
    No idea what the "real" story was though. Might be worth checking out.
    Rereading your question, maybe I was wrong in my assumption. Are you using a stock TB, and you have a "spare" bored one that you could try?
    Really doubt it's the TB if it's stock or aftermarket. (unbored) Leaks due to bad gaskets, injectors, or seals yes, bad casting that "just happened"? Highly doubtful.
  9. bigblock72
    bigblock72 1/2 ton status Premium Member GMOTM Winner
    Oct 18, 2005
    1,234
    58
    American Fork, Utah
    What do you have the timing set at? With that larger cam you'll want to set the timing up around 8-10 degrees. I'll bet your manifold vacuum is low enough to make the computer think the engine is under a heavy load and fuel the heck out of it. Bumping up the timing will help get the vacuum up some and help. Have you checked the fuel pressure as suggested before? high fuel pressure equals rich. Is the MAP sensor connected properly and getting an actual reading? Low MAP reading also causes a rich condition. Last but not least what are the specs on your cam? If it's over 220 duration (@ .050") or under 112* lobe seperation it will cause the idle vacuum to go low enough that it will be tricky to get the chip right and have it idle right and consistent. Make sure you don't let it run very long in this condition as it will wear the motor out in short order. Make sure you change the oil as soon as you can to get all that fuel saturated oil out.
  10. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    If it is a MAP issue you could just put a false vacuum to the MAP and see if it suddenly runs ok. Small vacuum pump like the Silverline things would do.
  11. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    Subscribing to this thread.
    Just got a 383 as well and it will be installed soon. Havent gotten the bored out TB yet, hoping it will do ok on stock for a little while.
  12. dyeager535
    26,979
    You've read the burned piston/383/TBI thread, right? (or burt(s?)4x4 454 thread)
    I wouldn't run it anymore than necessary until I got fueling dead on.
  13. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
    Well, I replaced the bored TB for the original and no more dumping of fuel. I guess I will replace once I'm ready for a new chip...
  14. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Good news! Change your oil and give the truck a good run.
  15. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
    On top of that, changed it the same day and ran until no more smoke. Will update later...
  16. Col_Sanders
    Apr 27, 2005
    5,688
    KFC
    Updates??
