TBI engine flooding
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by joker89blazer, Oct 17, 2002.
  1. joker89blazer
    joker89blazer 1/2 ton status
    Nov 21, 2001
    130
    panama city florida zip 32409
    89 blazer floods bad and stalls. Check engine light is not on when flooding. Where should I look for problems? If it was o2 sensor I would think motor would go into closed loop mode, but motor is running worse than closed loop mode. Could this be a problem with the vacuom control for the EGR valve, TPS, idle air control, sticking injector, something else ? Where should I start looking ? Thanks in advance for looking. /forums/images/graemlins/1zhelp.gif
  2. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Try your fuel pressure regulator. Mine ran real rich when it went, if you think it might be an injector, pop the air filter off and listen to the injectors, they will make little clicking sounds. They sound a little like loose valves, but quieter. If you here only one clicking then one of them is clogged or jammed.
  3. joker89blazer
    Nov 21, 2001
    130
    Thanks for the help, I didn"t think about checking the fuel preasure.
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Try unplugging the temp sensor - its a two-prong sensor near the front of the intake. Sometimes when they go, they register something obnoxious like -30 degrees. Mr. ECM sure dumps in the fuel at -30 /forums/images/graemlins/eek.gif Unplugging the temp sensor will just keep it in "open loop" - basically permanent warm-up mode.
  5. joker89blazer
    Nov 21, 2001
    130
    I have tried unplugging O2 sensor, coolant tempature sensor,MAP sensor all made no change. Installed new repair kit in preasure regulator. Tried unplugging each injector to see if one was sticking made no change. Truck is flooding so bad now that it only spits out black smoke when cranking at full throttle, will not run. /forums/images/graemlins/1zhelp.gif
  6. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    unplugging the coolant sensor makes it think it is cold (higher resistance=colder reading) try another temperature sensor or short the sensor connector with a small jumper wire, this may cause the check engine light to come on, but if it quits flooding you will know the sensor is at fault.
  7. joker89blazer
    Nov 21, 2001
    130
    Replaced coolant sensor. Installed rebuild kit in fuel regulator. Same problem as before. If I try to start with out touching throttle I only smell raw fuel, If I crank at full throttle truck will sputter out black smoke and sometimes backfire out intake. What am I missing ? Should I be looking for a iginition problem instead of a rich fuel condition ? Problem first started with truck stalling and black smoke. After driving home [less than 10 miles] engine will not even run. I don't think a timing gear/timing chain problem would do this. Should I be checking something in the iginition circuit ? If so what ? Thanks for the help already. Any other ideas ? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  8. joker89blazer
    Nov 21, 2001
    130
    Any ideas???????? /forums/images/graemlins/rolleyes.gif
  9. RedneckK5
    RedneckK5 Registered Member
    Aug 15, 2002
    42
    texas
    are you sure that you are unpluging the correct temp sensor? most computer controlled engines have two temp sensors. one for the ecm and one for the gauge.
  10. joker89blazer
    Nov 21, 2001
    130
    I tried unplugging and I replaced the sensor mounted on the front of the air intake than works with the ecm. I know what you are talking about there is another coolant sensor [mounted on the engine block?] that works with the tempature guage/idiot light. Thanks for the reply.Any other things to look for???? I don't know what else to check and the haynes manual is not much help with this problem /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/1zhelp.gif
  11. RedneckK5
    Aug 15, 2002
    42
    texas
    will the truck start at all. if so will it run at a higher rpm. have you checked the timing. how about the map sensor.
  12. joker89blazer
    Nov 21, 2001
    130
    Truck will not run. Truck will sputter out black smoke and backfire out intake and strong fuel smell if cranked at full throttle does nothing if throttle is not depressed during cranking. Can not get truck to run inorder to check timing.thanks for the help.
    Anything else?
  13. RedneckK5
    Aug 15, 2002
    42
    texas
    make sure the distributor is tight and hasent moved. you might get a buddy to crank the truck while you screw with the timing. make sure to mark it before you move it so you can put it back if it doesnt help.
  14. NEOMASTINO2U
    NEOMASTINO2U 1/2 ton status
    Jun 29, 2002
    518
    lynnwood, washington
    i don't know if this will help but i had an 87 tbi and ran into a similiar problem, it would load up with fuel and die know matter what, after tearing it apart and looking at everything and replacing things it came down to a clogged pvc passage which is part of emissions crap. unfortunatley emissions stuff controls so much on the vehicle. but mine did almost the same thing flood itself out and puff out black smoke and sometimes backfire. don't know if this helps but good luck finding the problem.
    kelly
  15. joker89blazer
    Nov 21, 2001
    130
    Thanks for the help. I will check the distributor and the pcv system for problems. I'll post back what ever I find.thanks again.
  16. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Did you change timing gear or chain or you were asking if you should check this?
    If you did change them, that is one thing I would check, you could be one tooth off and that would be your problem.
  17. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    What about the engine code(s)?
    Could be leaking injectors... /forums/images/graemlins/frown.gif
    I hear people upgrade to the Holley's for this exact reason.
    Good luck.
  18. joker89blazer
    Nov 21, 2001
    130
    Did not do anything to the truck before problem. I am starting to think problem maybe in ignition or timing and that computer is dumping extra fuel in becouse of another problem. I pulled the iginition module [part under rotor and cap] and the coil I going to have autozone check these parts. I have have been told that the module can be bad and the tester say it is good so this may not help anyway. To rotate motor to tdc for timing check , should I remove the plugs, are is the crank bolt strong enough to rotate motor under compresson ? On my toyota I would turn motor over with plugs in, can I do this on the 350 with out risk of breakin bolt off in crank, already have enough problems with out making more. I have tried unplugging one injector at a time to see if one was bad, did not make any changes. Can not make truck run so there is no codes stored. thanks for the replies guys.
