TBI fittings
Discussion in 'The Garage' started by Diesel Dan, Apr 15, 2006.
  1. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Looking for a supply source for some TBI fittings.
    Working on installing a carbed 383 into a '90 K5. What I am doing is using the stock in-tank pump/lines/filter. From the filter on I will replace with braided line and JIC fittings to the regulator and carb. Need female fittings on the end going to the factory lines and NPT or JIC on the other end.
    Anyone done similar?
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    earls are good for fittings. You could get barbed spigot fittings from turbo city to go on to the filter then go rubber line from there. Or buy one of their filters that accepts rubber hose and put a short piece of hose from the steel line to the filter then after the filter to your reg.
  3. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    should be 16 mm o ring fittings. same ones used on ps pumps. just ordered 4 for my ps conversion. 16 mm oring tp -6 an same as jic 3/8
  4. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    Don't really want to use any more rubber hose than absolutely neccesary. This is a buddies blazer and he already had one burn to the ground once because of others cutting corners. I built the motor for this truck, again, and am now installing it for him.
    16mm O-ring fittings?
    Will dig around and see if I have some extra P/S hoses to compare too. If not then I'll pull the ones off the blazer and compare. However on the male end of the fuel line it takes a ~5/8" wrench and the male fitting of the P/S hose uses a 3/4" but haven't measured the diameter of the lines yet.
    Will check with jegs on the earl fittings and if nec get a # for their tech dept.
    Thanks.
  5. hero
    hero Registered Member
    Oct 21, 2002
    65
    Omaha, NE
  6. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    hero,
    Nice looking fittings and will keep them in mind for future projects. However that is a male saginaw to male -AN adapter. I am looking for a female saginaw to male -AN fitting. Similar to the fittings in the back of the TBI unit.
    Found an Accel part thru JEGS, 310-74743H, but no pic to see if it is what I want.
  7. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
  8. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    Thanks Ryan:D ,
    I was going to email the companies but you responded before I could. Looks like the 14&16mm are the ones I need. The smaller of the P/S fittings fit the larger of the fuel line and IIRC the pressure hose of the P/S is 18mm.
    Price is good at only $8.69 thru summit, prefer JEGS but summit stocks the Holley 12-803BP regulator I want to run while JEGS has to order it.
    Thanks for all the help:waytogo: .
