TBI fuel fittings
Discussion in 'The Garage' started by BigJohnson, Jul 16, 2003.
  1. BigJohnson
    BigJohnson 1/2 ton status
    Jan 22, 2001
    207
    AL
    Please help!
    I have searched and searched and can not find what out what kind of fuel fittings screw into the tbi injector pod. What is the correct name of these fittings and where can I find an adapter to adapt them to a push lok fitting for rubber hose or AN fitting? I know others have discussed this but I can't find info on these things.
    I was told Parker makes an adapter to adapt the fittings to a barbed push lok type connector for use with high pressure rubber hose. I would like to use that fitting but cant find it anywhere.
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
  3. BigJohnson
    Jan 22, 2001
    207
    AL
    Man your a life saver! Thanks a million...
