tbi Fuel pressure gauge
Discussion in 'The Garage' started by 91GMCSuburban, Sep 10, 2004.
  1. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    Anyone seen a fuel pressure gauge with a max of about 20 psi? I want to install one on my tbi moter.
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    only FP gauges I have seen ate 15psi max and 100psi max... I am trying VERY HARD to find a mechanical gauge that has like a 20psi or 30psi max as my TBI motor is at about 18psi unter full load...
    I am currently using a AutoMeter 15psi gauge and the FP gets PEGGED at WOT...
    Chris
  3. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Here's what I have:
    http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=1597&prmenbr=361
    30 psi max.
    I've noticed that it reads incorrectly when it gets heated up. Apparently this is just the way it is for the fluid filled gauges since the fluid expands and fights against the fuel pressure resulting in a low reading. It reads right when cool though.
    The slick setup is to run tubing into the cab, maybe that's what you had in mind anyway.
  4. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Can this be used with an (Autometer?) isolator (for incab installation)? Do you know what diameter the gauge is? 2 1/8"?
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    [/ QUOTE ] /forums/images/graemlins/yikes.gif
    A fuel line in the Cab?? /forums/images/graemlins/yikes.gif No thanks! Burning to death aint my idea of a good time.
    Do it right! Use an isolator. /forums/images/graemlins/thumb.gif
  6. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    No, they have isolator tubes with some other kind of fluid in them to transmit the pressure into the cab.
  7. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Oh sorry man.... I just didn't want someone to get the idea they could run a fuel line in the cab.
