tbi fuel pressure regulator?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by leadvillek5, Mar 11, 2005.
  1. leadvillek5
    leadvillek5 Registered Member
    Nov 20, 2004
    85
    leadville colo
    ive done some seaching and found that there is an adjustable fuel regulator and a vaccum reference pressure regulator. which one is the better?
  2. crazy427
    crazy427 1/2 ton status
    Mar 10, 2003
    979
    Edison , NJ
    the vacuum refrerenced regulator is adjustable also so it is the best of both worlds.
    i am selling one ,if you are interested pm me
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have an adjustable FPR. But as said. The vacume FPR is the best of both worlds. Gives both economy and performance. without a bunch of tuneing.
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I had the JET FPR and it SUCKED just as bad as the stock regulator. You can crank up the FP but then the truck runs pig rich at idle. The VRFPR is awesome. keeps 12psi at idle and boosts it to 18psi at WOT.
    Here you can see the VRFPR and the feed line adapter for my FP gauge...[​IMG]
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Ok, i'll bite. What does this VRFPR do? Is it an adjustable regulator that also helps richen fuel at WOT? How does it work? How much do these things go for and why are you selling yours?
  6. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    also where can i get one new if i want one thanks.
  7. crazy427
    Mar 10, 2003
    979
    Edison , NJ
    The vacuum refrenced regulator is adjustable . what you do is trun the srcew in the bottom to adjust max fuel pressure. then you hook up a manifold vacuum source to the regulator so at idle ( when vacuum is high) it puuls the fuel pressure down so the truck doesnt run rich as hell. then when you get on the gas vacuum drops and fuel pressure increases when you need it. I have a post in the seller forum with my VRFPR , cusion valve ( gets installed in the vacuum line so the drop and increase in vacuum isnt instant and the fuel flow is gradual and not a hit) and a set of venom high perfomace injectors that flow 10 % more than stock injectors.
    http://coloradok5.com/forums/showthread.php?t=131225
    I removed the set -up becuase i am now running a 383 and the injectors couldnt support the fuel flow i needed. So i am now running a set of 80lbs injectors with a stock modified regulator set to 12 lbs and a tpi fuel pump.
    PM me if interested Joe
  8. crazy427
    Mar 10, 2003
    979
    Edison , NJ
    Dealer carries them new, if you do a search you should be able to find a part #.
  9. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I like the sound of this reg but can't find it on the net. Any idea who makes them? Thanks.
  10. leadvillek5
    Nov 20, 2004
    85
    leadville colo
    vfpr
    thank you for your post. i found the PART# gm17113186 around $62.00 my cost new. how much are you selling just the vfpr? cannot afford the injectors but definitly need them for my engine application.
  11. dyeager535
    26,977
    OUR PRICE: $43.97 (gmpartsdirect.com)
  12. leadvillek5
    Nov 20, 2004
    85
    leadville colo
    cool thanks for the heads up on that $ and site:D
  13. dyeager535
    26,977
    Just watch shipping though...I believe they have gone to a percentage of cost for shipping/handling, which should be better than it used to be, but still seems high. That's how they make their money though.
    Still cheaper than buying local for me, my dealers here suck.
  14. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    Okay just a couple quick questions:
    Where is the best place to T into for the vacuum?
    And is the factory vacuum regulator adjustable?
    If so do you need to take the injector pod off to adjust or not?
    Tim
  15. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Sounds like this could be a new tech write up. Show install, sources and how it works!
  16. crash81
    crash81 1/2 ton status
    Jun 19, 2005
    289
    roxboro,nc
    what is the part # for the vrfpr i looked for it but had no luck.
