TBI fuel pressure
Discussion in 'The Injection Section' started by mouse, Jun 10, 2006.
  1. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I just wanted to see what everyone is running for fuel pressure on a small block TBI.
    I just installed an adjustable regulator, and have turned it up to just under 13 PSI. After datalogging I see my BLM numbers are still a bit high at 800 - 1200 rpm (see below), and will probably bump the pressure up a little more. I will re-burn the chip to smooth out the mid range.
    Engine specs: 350, .040 over silvolite pistons, 8.8:1 compression, comp cams xtreme energy cam, 388 heads with casting flaws removed, exhaust ports smoothed and 1.84 intake valves and bowl work for flow. Stock TBI intake and exhaust manifolds. Dual 2 1/2 inch exhaust. Stock TBI ignition.
    Narrow Latest
    RPM \ MAP 20 30 40 50 60 70 80 90 100
    400 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
    800 0.0 135.0 133.0 0.0 135.0 0.0 0.0 0.0 0.0
    1200 0.0 135.0 139.0 145.0 140.0 0.0 0.0 0.0 0.0
    1600 135.0 172.0 158.0 157.0 146.0 135.0 0.0 0.0 0.0
    2000 135.0 131.0 172.0 170.0 158.0 0.0 137.0 0.0 0.0
    2400 127.0 0.0 0.0 0.0 0.0 134.0 172.0 0.0 0.0
    2800 0.0 0.0 0.0 0.0 0.0 139.0 128.0 0.0 0.0
    3200 127.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
    3600 0.0 131.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
    4000 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I think they recommended like 20 psi for my 383. Im gonna fire it up in the next few weeks so we will see. :D
  3. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    I did some more tuning and was finally able to start pulling some rich BLM figures once I got the fuel pressure over 17.5 psi.
    I am getting the tune pretty close. I am aiming for the "perfect" 128 across the board...
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    quick question about this. Can you just buy an inline regulator? How is the pressure regulated stock? Will you see gains on a mainly stock tbi 350 with this upgrade?
  5. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    In stock form my regulator was set to 9.25 psi. After making it adjustable I bumped it up to 12. Never ran a scan on it.
  6. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    so you just replace the stock one with an adjustable regulator?
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yeah, there a few adjustable ones that replace the stock one in the TB unit. I use a Jet one. I bought a VRFPR but after reading that you need to mess about with different spring rates I gave up! Thet were designed for 454s so give too much pressure for a 355.
    I've also drilled out the cap on the stock one and adjusted it that way before.
  8. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Nope, I used the stock regulator but removed the limiter pin the factory installs to keep you from screwing with it.
  9. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    I replaced mine with an adjustable, but the stock pressure regulator can be modified to adjust.
    I bought one that could be adjusted without removing it from the truck...
  10. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Which brand or vendor did you buy from that it can be adjusted without removing from the truck? It looks like either the CFM-Tech or the Turbo city can be adjusted while still installed but i'm about to buy one and want to make sure beforehand.
  11. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I used a Jet one which can be adjusted with an allen key (or wrench...whatever you guys call it!!!)
    I think the Turbo City one has a knurled thumb wheel adjuster doesn't it?
  12. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    I gotta ask this only because I recently got an old style engine analyzer and have been looking at data on my '87 TBI Blazer. In road test mode my " Block Learn" numbers are always 108 to 112 and the integrator numbers (short term adjustments) are between 120 and 130. Now I always thought my engine was running on the rich side, but your post leads me to believe I'm actually lean all the time? By the way, I have no drivability problems or engine codes, I'm just trying to anderstand how the stock engine is running before I start any mods to it.Thanks for your time.
