TBI fuel pump fittings
Discussion in 'The Garage' started by 74kay5, Mar 16, 2006.
  1. 74kay5
    74kay5 1/2 ton status
    Oct 30, 2003
    486
    San Jose CA
    Anyone know off hand what kind of female fittings will work with the male 3/8 and 5/16 fuel pump outputs? I'm replacing the old steel braided flex lines with new ones.
  2. sweetk30
    Nov 1, 2004
    25,552
    545
    horseheads , ny 14845
    gm specific. flared lip with oring. you can get lines at stealer. pricey tho. try junk yard and cut off rubber sections and just use the ends with new high pressure fuel injection hose.
  3. 74kay5
    Oct 30, 2003
    486
    San Jose CA
    I already have all the fuel line I need. I just need the right adapter for the connections.
  4. dyeager535
    26,982
    191
    They make adapters for the Saginaw fittings to AN stuff, but the cost of the fittings is so much that I found it better to just use GM parts.
  5. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
  6. hero
    hero Registered Member
    Oct 21, 2002
    65
    Omaha, NE
    Go to www.speedwaymotors.com and look up part# 6174806 $7.95. It's a AN #6 to 16mm. They also have the #6 to 14mm. I used these fittings and it worked fine.
  7. 74kay5
    Oct 30, 2003
    486
    San Jose CA
    Cool the 14 and 16mm adapters are exactly what I was looking for, thanks
