TBI fuel pump replacement- get the whole assem. or just the pump?
Discussion in 'The Garage' started by COCHEV, Apr 30, 2004.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    i can get just the pump and screen from napa for like 60 bucks or get the whole assembly with sending unit for 260 bucks. big price difference /forums/images/graemlins/shocked.gif can't be too hard to just replace the pump, rught??? any one do this?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just replace the pump unless your sender is bad.
    And get your pump from somewhere besides Napa, you can get the same pump with a lifetime warranty somewhere else for about $40.
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    It you get the pump at napa, make sure you get the ACDelco replacement pump (should be an EP386). Once the tank it out, use a brass drift to undo the locking cam ring and the entire sender comes out then there is a hose clamp that holds the a little section of fuel line to the outlet of the pump, Remove the clamp, remove the old "sock" filter, remove the rubber isolator under the pump and replace the pump, filter, isolator and you may need to replace the little section of fuel line...
    Yeah, you only need the entire sender if the send protion is not working right...
    Chris
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    .....Once the tank it out, use a brass drift to undo the locking cam ring.....
    The brass drift is the key... NO SPARKS! /forums/images/graemlins/waytogo.gif
    John
  5. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    John
    A wooden dowl would work well too!
    This is correct. Sparks around a fuel tank are BAD /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/shame.gif
    Chris
  6. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Just pickup a new pump. Not hard to replace at all unless you have to drop the tank while its full /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif In my S10 I just took the pickup bed off when I did my pump because it was easier than dropping a full tank.
