tbi fuel pump
Discussion in 'The Garage' started by sledheadak, May 25, 2006.
  1. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    im starting my tbi 454 swap into my jimmy next week and havent found a k5 fuel tank and pump yet. is there a aftermarket fuel pump that will work with the tbi system?my donor is a suburban and the tank is too large to fit.i did a search but didnt find what i was looking for.thanks
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    turbocity do all that TBI stuff. I used one of their inline TBI pumps which they also supply with their TBI kits. They're a bit noisey but any pump would be when it's outside of the tank.
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    When I converted I ordered a new steel tank from O'reilly's and used the in-tank pump. The main advantage to TBI is to operate at extreme angles, and the proper, baffled tank with an in-tank pump is a must. Cost was ~$100 and it uses a steel baffle versus the plastic stock one (which can break easily).
    Plus, I like using stock replacement parts - they're easier to find when you need them.
    I looked in the local junkyards for one before ordering...too few K5's to pick from!.
  4. JUNIOR-K5
    JUNIOR-K5 1/2 ton status
    Dec 20, 2005
    387
    SO.CAL
    I did the same swap on my k5 and used a 30 gal. tank with a 40 gal. tank sending unit off a sub. All you need to do is buy a tank.
  5. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    You can also check out howellefi.com they have an external inline pump.
  6. dyeager535
    26,979
    :thumb:
  7. sledheadak
    Apr 29, 2005
    1,283
    anchorage,alaska
    thanks for the replies :thumb: :thumb: now i just have to find a good tranny case lol
  8. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    What are you looking for?
