tbi gurus look! need a new motor
Discussion in 'The Garage' started by chevycanada, Jul 6, 2002.
  1. chevycanada
    chevycanada Registered Member
    Aug 14, 2001
    33
    Comox BC
    i am goin to starting the new motor for my truck in the next month or so, but i need to find a core. my question is do i need to find a 87 or new block or can i use and older one? i will be running the stock TBI but the 87 TBI intake is a diff bolt pattern then and 86 or older motor? is there a TBI intake that will fit an older motor or can i just swap the heads from my 87 onto say an 82 block?
    thanks
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    The main diff between a pre 85 block and heads and post 85 is the one piece rear main seal and the 4 center holes on the heads. They go straight down instead of being angled. If you put newer style heads on an older block I think the only difference would be having a two piece main instead of the one piece. I think the oil pans and pan gaskets are different too. I'm sure it would work tho. You can buy a new motor from the dealer for less than $2000. The core charge is only $100. I hope I made some sense. /forums/images/icons/smirk.gif I've been installing a new motor all night. The beer is weighing a little heavy right now.
  3. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    What Jimmyjacl said... The heads and intake changed in 87 to hve a different angle, and I think again in '88, but I'm not sure. Heads will bolt to any block from the late 50's to late 80's I think...
  4. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    The other difference is that you'd need the older style flex plate or flywheel. It's not just the rear main seal that was different, the bolt pattern holding the flywheel or flex plate was different too.
    Rene
