TBI gurus....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by moneypit, Feb 13, 2004.
  1. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    I am converting to TBI on moneypit2. Question is I have a fuel cell with sump, can I run a external electric Holly pump that puts out 45psi? Will the TBI unit regulate it without any issues? Or should I add a external regulator also? Thanks-moneypit /forums/images/graemlins/1zhelp.gif
  2. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    TBI is regulated at 9 -13 pounds so a regulator will be needed.
    Also i believe someone said they make baffled fuel cells so you can run an 87 up sender with pump...if not with a frame mount pump you will still run into the dreaded stumble when she sucks air...with a baffled tank with in tank pump this is avoided. A trick years ago was to pump from the tank to another pump located in a small secondary holding tank so that the stumble when air is sucked was kept to a min.
    DW
  3. moneypit
    Sep 3, 2000
    1,382
    COLORADO
    Will the built in regulator in a Holley 670cfm TBI regulate it or do I need a second regulator?
  4. BigJohnson
    BigJohnson 1/2 ton status
    Jan 22, 2001
    207
    AL
    Yes, the TBI regulator will handle 45psi. With that pressure you may need to make your FPR adjustable. Here is a link for that. The TBI regulators are bypass style, I believe that is what you call it, it is on the return side of the injectors and regulates the fuel pressure by raising or lowering the return flow. From what I read you can run up to 20-25psi safely through TBI injectors and greatly increase the lb/hr flow rate. But, if you do this you will need to reprogram your eprom if you make significant changes in injector flow rate.
