TBI Heads cc?
Discussion in 'The Garage' started by jimmy'sjimmy, Jun 29, 2006.
  1. jimmy'sjimmy
    jimmy'sjimmy 1/2 ton status
    Dec 22, 2001
    130
    Greenwood Village, CO
    Wondering what size the stock TBI heads are? I thought they were 64cc but I was talking to a guy at a machine shop and he said they are most likely 76cc. Anyone no for sure?
  2. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
  3. jimmy'sjimmy
    Dec 22, 2001
    130
    Is there anyway to tell for sure? I found some other sites that say these are 76cc no matter what. just want to be sure before i buy this short block or my compression will be way too hi.
  4. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    the only sure fire way to know is to check the head casting number in a part's book. Do you have the casting number?
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    350s had 76ccs
  6. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    The heads I had were 64s, so maybe 305 heads, but all I know is they made my TBI406 a MONSTER!!!!
  7. TallCowGirl
    TallCowGirl Registered Member
    May 20, 2000
    35
    New Mexico
    1987-88 EFI Swirl Port Head
    Hi There...I had a 383 engine made from an 1987 TBI 350. The head casting number was 14102191. The engine builder thought the head chamber volume was 76cc's, but (after lots of research and asking people) it turns out that 14102191 or 14102193 heads have a 64cc chamber volume.
    Hope this helps,
    Diana
  8. NateInChandler
    NateInChandler 1/2 ton status
    Apr 23, 2006
    418
    Chandler, AZ
    Actually im not so sure that 350's all had 76cc heads, some of the 90-93 TBI motors were rated at 9.5:1 compression and that isnt gonna happen with 76cc heads and a flat top piston. I know my motor puts out almost 180psi in each cyl and its a bone stock 91 TBI Motor.
  9. jimmy'sjimmy
    Dec 22, 2001
    130
    casting # ends with 191
  10. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    TBI heads are 76cc chambers, it's the vortec's that have 64cc chambers.
  11. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    so do you want bigger or smaller???what is the main difference??? :crazy:
  12. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    I'm assuming you're refering to chamber size. That all depends on what compression ratio you're looking to achieve. If you have 76cc heads and want more compression then going to a smaller chamber will achieve this but may not always be a good thing. Compression, cam, and induction all work together to form a package that will make torque and HP but changing one thing and not the other could be counter productive.
