TBI hesitating BAD!!
Discussion in 'The Garage' started by muddysub, Sep 12, 2002.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    when i get on it from a stop light it will just kinda die and idle for a few seconds then all of a sudden VRROOOOMM!! it's hesitiating really bad what is wrong? it does it when it's cold but it's not cold out at all like 80-85deg right now. i plan on replacing a fuel filter and rebuilding my TBI will that cure it? /forums/images/icons/confused.gif
  2. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    sounds like a vaccuum leak
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Mine will kinda do the same thing. If, from a stop or while driving, I press down on the accelerator quickly, the engine will bog for a second and then really go.
    Anybody else have this happen? What'd you do to fix it?
    If I had to guess, I would say that the opening of the butterfly valves so quickly, either chokes the engine with air (not enough fuel mixed in), or too much fuel enters and the engine bogs. I couldn't begin to tell you how to fix either of these situations though.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    My S-Jimmy was doing this last year. It was driving me nuts. Then I was taking the factory air cleaner off for something and noticed that the little return spring for the thermostatic air valve in the snorkel had broken. I fixed the spring and the truck hasn't hesitated since. /forums/images/icons/cool.gif
    I think that without the spring, the valve would just flop open and closed as the truck accellerated. When it slammed closed, intake vacuum would rise, causing the MAP sensor to send back a high vacuum signal, confusing the heck out of the computer. Just one of those odd things to check. /forums/images/icons/cool.gif
  5. muddysub
    Jun 23, 2001
    10,451
    489
    i have a 14x4" open K&N air cleaner, so i'm getting plenty of air. a vacuum leak?! aw man!! /forums/images/icons/mad.gif
  6. muddysub
    Jun 23, 2001
    10,451
    489
    did i mention it only does it at certain times? like i start it up and leave it does it on the way out but after it's been driven for a few minuites it's fine. like i said it's not cold. /forums/images/icons/confused.gif
  7. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    So its when the computer system is in "open loop".
    I'm no emissions pro, but that thermistatic flaper thing that HAIR-E was talking about could possibly causethat if it is staying open. It's supposed to stay closed while cold so the exhaust heat can help warm up the intake.
    Another thought would possibly be a faulty throttle position sensor maybe.
    A thought.... Even if you aren't getting any codes, go ahead and jumper off the diagnostic port and see if the computer is storing a code in memory.
    Good luck!
  8. muddysub
    Jun 23, 2001
    10,451
    489
    thermostatic flapper thing??? /forums/images/icons/confused.gif /forums/images/icons/confused.gif where is that?
  9. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    It's in the snorkel of the origional air cleaner. It has that metal hose that goes down to the exhaust manifolds.
  10. 2BLAZERS
    2BLAZERS 1/2 ton status Premium Member
    Oct 12, 2001
    513
    4
    KEIZER, OR
    I have had the same issue before. What cured mine was a new cap and rotor with new spark plug wires. The cap and rotor were diffently warn. This is only a 30 dollar fix and anyways when was the last time you changed them.
  11. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I agree a bad TPS could do this. Easy to check with a voltmeter or even an ohm meter depending on which way you went.
