TBI Idle Problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tom, Aug 15, 2001.
  1. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    Our '90 TBI blazer runs great, except that the computer won't let the RPM drop rapidly when the gas pedal is released. This is a real pain with the stick shift (SM465). It makes shifts slower and rougher than normal. Is there a way to correct this? My guess is that this feature is part of the smog control system. The TBI is better than the quadrajet in every way except for this annoying characteristic. Thanks in advance for any help or ideas.
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Gas pedal released? Okay. Anyway, sounds like maybe the TBI gasket is bad. Easy way to check is spraying carb cleaner (correct me if I'm wrong, can't remember what was used) around the TBI and this will find the leak if there is one. Gasket kits are cheap and easy to replace.
    Bubba Ray Boudreaux,
    Leader of the Advance Party for
    the CSA revolution in the PRK!
    <a target="_blank" href=http://community.webshots.com/user/mdntrdr1>http://community.webshots.com/user/mdntrdr1</a>
  3. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    I had a high revving problem also that kept me from passing smog. They wanted 400 bucks to diagnos and fix the problem. Turned out to be a leaking TBI gasket. Like was mentioned, use carb cleaner and listen for the RPMs to jump a little. It's easy and cheap to check for this and the repair (gasket) is about $10 and about an hour to do. Check this fist.
  4. 90idahoblazer
    90idahoblazer 1/2 ton status
    Jun 24, 2001
    183
    Idaho
    Do you spray the carb cleaner around the base of the Gasket...Also have any of you adjusted the idle on a TBI..???or is it computer controlled only
  5. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    TBI with high ildle concerns;
    -Check for TBI gasket leaks, very common problem. way-outside (fumes will bring tears to your eyes), spray the base of the TBI, engine idle should increase if there is a leak.
    -Check for throttle shaft bore wear. Grab the throttle shaft and wiggle it, there should only be rotational movement and no "slop" in the shaft. Also, spary carb cleaner around the shaft will also help find the vacume leak.
    -Check throttle bores for contamination, use carb spray to clear and clean.
    (there are someother possible causes to engine idle concerns, I have found the list above to be the most common)
    TBI idle sys is controlled by the IAC (Idle air controler) and ECM. Do not atempt to adj engine idle externaly.
    <font color=white>It's good to be out</font color=white>
    <font color=white>Out of my mind and out of control</font color=white>
    <font color=blue>Twiztid</font color=blue>
  6. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    That's an emissions-control feature programmed into the computer. Do you have any other engine mods? If so, maybe <a target="_blank" href=http://www.fastchip.com>www.fastchip.com</a> can burn you a new chip that doesn't have that feature.
    It's always darkest just before it goes pitch-black...
    [​IMG] <font color=green>Semper Maintenance!<font color=black>
