TBI idle surge and stumble: UPDATED SOLVED
Discussion in 'The Injection Section' started by Cricket, Jun 19, 2006.
  1. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    TBI is surging with steady part throttle in open loop when cold. Especially when it's been driven - shut down for an hour - and restarted. The surge is like a whup-whup-whup-whup until I add throttle and rev it out. It goes away after I drive it for a minute or it warms up to closed loop.
    It does this with both old and new TPS but with the new TPS the acceleration stumble remains. All other sensors are new.
    Any ideas? :dunno: The open loop/ closed loop is throwing me.
  2. 88-383
    88-383 1/2 ton status
    Sep 11, 2005
    142
    Tracy. CA
    Is this a completely stock setup? If not, can you list the mods? Did the problem first occur after any work? Has the check engine light ever come on?
    KM
  3. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Stock set-up off a 1990 C1500, painless harness, VSS, Gerotor pump on a stock saddle tank, all new sensors.
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Have you driven it at a constant 30mph-ish just to let the ecm relearn the parameters?
    Have you connected the N/P sensor? If the ECM doesn't know you're in neutral or drive it can cause that effect.
    Having said all that, my '05 Ram does it occasionally!
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    WHere excactly is the N/P sensor located, Mark? I'm having a few "stumbling" issues myself at idle, but only in Park. Once the sucker is thrown into Drive, the idle smoothes right out.:confused:
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    On the base of the column shift. It acts as an inhibitor and a switch to tell the ecm that you're in neutral or park so it can compensate for higher idle without load. When I put a B&M shifter in my '78 I forgot to connect it up and it acted a bit screwy.
    My '91 has never had a 'really' steady idle, but checking it with Winaldl it seemed that it was just a result of it continually trying to lean it out then bring it back again which is apparently correct. I think my ecm was just a bit too enthusiastic!
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I would check the temp sensor.
  8. 88-383
    Sep 11, 2005
    142
    Tracy. CA
    Does it rev out smoothly in neutral when you're having trouble? Is it like a flooding problem?
  9. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    possibly a sticky EGR valve.....or clogged IAC passages?
  10. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Neutral or drive, any super light part throttle application would create a series of jerks or surges as if you were purposely tapping the throttle in a steady drum beat. If you just popped a little deeper into the throttle it would disappear.
    The latest report: Okay I have had some positive results with fuel injector cleaner. I've run two tanks through with BBK and the surge has seemingly been eliminated. The throttle is much smoother and more responsive. My guess at this stage is that my injectors were a bit plugged up.
    If the EGR had been sticking it would have thrown a code 32 - something I am all too familiar with.
  11. Cricket
    Nov 29, 2004
    8,224
    Colorado
    UPDATE: I found a very small vacuum leak at the EGR base gasket. Replaced the gasket and that got rid of the last bit of hesitation. The leak was small enough that it would not stumble/surge under regular acceleration but with powerbraking or feather light throttle it became very apparent.
    I had two problems at once. Partially clogged injectors and a small vacuum leak. Now that the leak is sealed and the injectors are clean it's running great.
    At least for today.:D Hallelujah.
  12. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
  13. 94yukon
    94yukon 1/2 ton status
    Aug 20, 2005
    122
    Minnesota
    Im working on a 94 with a check engine light and a knock sensor circuit code i replaced it and repaired the bad wire and connector. I did tune up timing etc. the problem has been there since i bought it . also the scan tool indicates that the truck is in d2. i no longer have a 700r4 and dont remember seeing a switch on the tranny.
  14. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    my idle
    it seems to surge alot, especially when in drive? any ideas?
  15. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Does it surge while accelerating or just idling in drive with the brake on. Warmed up or cold? Stock TBI or swap?
  16. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    brake on, both, and stock
  17. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Sounds like a fuel delivery problem. Take off your air cleaner and watch your injectors for a good spray pattern. Are they dripping at all? If you don't see a problem there then put on an inline fuel pressure gauge and check the pressure. Based on previous runability problems I've seen on the board it has usually been the in-tank fuel pump.
  18. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    actually, i think it only does it when its warmed up
  19. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Here is another easy check with only two possible outcomes. Does the engine surge while holding the accelerator steady?
    If so you have an intake leak or fuel delivery problem.
  20. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    no it doesnt
