TBI idle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sharkman726, Dec 16, 2003.
  1. sharkman726
    sharkman726 Registered Member
    Apr 20, 2003
    22
    VA.
    I recently added a TBI spacer on my 90 K5. I just noticed my idle appears to be a little high. Can you do anything on a TBI to adjust the idle. Sorry if this is a moronic question but I am a little confused on this.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
  3. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Hey man Im not too sure on your question but Im in Virginia too..and have a 90. /forums/images/graemlins/thumb.gif Where are you located? Im live in Richmond but go to school at Virginia Tech. You got pics of your rig? Im puttin 6" and 35 BFGs and would love to see it. /forums/images/graemlins/thumb.gif
    Oh im sure someone will tell you but make sure your TV cable is properly adjusted after putting that spacer in..dont want to toast that trans.
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Sounds like you have vacuum leak.. Check the gaskets and make sure you torqued everything correctly. /forums/images/graemlins/smile.gif
    John
  5. sharkman726
    Apr 20, 2003
    22
    VA.
    Thanks for the input. (good link) I think I understand the TV cable concept now. I will try to make the adjustment today.
  6. Jays Beast
    Jays Beast 1/2 ton status
    Aug 7, 2002
    538
    Chandler, AZ
    How tall of a spacer is it? If it is over 3/4" you need to install spacers under the bracket that holds the tv cable and throttle cable. This is to help eliminate binding of the cables. Also check all the vacum hose connected on the TBI might have a cracked hose/hose connector, from moving the TBI.
  7. Silverado_K5
    Silverado_K5 1/2 ton status
    Jun 4, 2003
    707
    Weston, Oregon
    If you don't have any vacuum leaks anywhere, you can remove the little round plug up on the right top corner in the front of the tbi and adjust the MAR=minimum air rate or idle screw.
    Doug
