tbi injector pod spacer ???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tx_sub, Aug 10, 2004.
  1. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    for those who have installed the injector pod spacer, did you remove the throttle body housing completely, or could you do it in car. could you just unscrew the pod unit and slip in the spacer without undoing the fuel lines and electrical connections? thanks for your help.
    TC
  2. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I did mine when I did the throttle body spacer, so I did remove my whole throttle body, however you can do just the injector spacer without removing the tb. It was a very simple install.
  3. crazy427
    crazy427 1/2 ton status
    Mar 10, 2003
    979
    Edison , NJ
    i installed mine right on the truck ,just be carefull no to drop any of the little screws down the throttle body in to the intake
