TBI injector question
Discussion in 'The Garage' started by my87Half-ton k5, Jan 12, 2006.
  1. my87Half-ton k5
    my87Half-ton k5 Registered Member
    Jan 9, 2006
    35
    NH
    i have an 87 350 tbi K-5: my question is this,
    if one injector is stuck open will it affect all 8 cylinders or just the side that the injector is mounted on?
    thanks
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    opposite side from the one the injector is mounted on.
  3. my87Half-ton k5
    Jan 9, 2006
    35
    NH
    but it couldnt possibly affect both sides? i mean if its stuck open? on both sides my plugs were black
  4. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    It will affect two on one side and two on the other, at least on a stock manifold.
  5. my87Half-ton k5
    Jan 9, 2006
    35
    NH
    ok i checked the front two spark plugs on both sides of the motor those are black which injector would that be
  6. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    you mean 1 and two or the first two on one side?
  7. my87Half-ton k5
    Jan 9, 2006
    35
    NH
    i mean the two spark plugs on the left and the right sides of the front of the motor...totalling four plugs...two on the left two on the right..which injector runs those plugs
  8. dyeager535
    26,979
    Sure it will affect all of them...the O2 sensor will see the additional leftover fuel and try to compensate.
    As mentioned, the stock manifold doesn't simply feed 4 runners on one side and four on the other, they are mixed up. Someone here knows the pattern guaranteed. :)
  9. my87Half-ton k5
    Jan 9, 2006
    35
    NH
    ok that answers my question better...thanks
