TBI injector replacement
Discussion in 'The Garage' started by Mastiff, Apr 6, 2006.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I'm in the midst of replacing the injectors on my TBI. The injectors are very resistant to seating all the way down into the pod. I think it's just because two different o-rings need to be compressed. What's the proper way to do this? Should I try to seat them before screwing the top on, or should I use the screw torque to squeeze it all together? I tried screwing it down, but it's getting pretty tight and I don't want to bust anything.
    I'm also not 100% sure the injectors are oriented correctly. I have them so the elctrical contacts are left/right and the little nub on the injector is to the back.
    Hopefully someone has done this recently and can help out. Google isn't helping...
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    they should seat pretty easy, i would not use the top to seat them becase it is a thin casting and i think it would break pretty easy. I would take them back out and make sure you have the orings on right and did the bore they go in is clean
  3. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Hmm. I wonder what I'm doing wrong. The old ones were also hard to get out. Not real hard, but I did need to grip them with pliers and they sort of popped out when I pulled.
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    make sure that there is not a old oring still in there, also make sure the center tip is centered in the bore
  5. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I got it. I did use the screws to pull it together, but it wasn't much torque once I got it lined up right. My problem was that the little nub on the injector goes toward the back on one side and the front on the other.
    Now I have "cop car" injectors. Time to get the chip tuned...
  6. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Let us know how it runs after the re-program.
