TBI intake manifold
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Mar 29, 2003.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    just pulled it off...the back two water passages were blocked off, had a foil looking thing over them...what was that? Also i think its the worst feeling in the world when your on the last bolt, seal already broken and you find a vac. line coming off the throttle body going nowhere...when a vac leak somewhere was the problem
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Sorry to hear you went thru all that work and found the vac line off. If it is the one in the back of the throttle body it is suposed to go the MAP sensor.
    I know there is a reason for those back water passages to be blocked off but I cant rember why.
    Good luck getting it back togather and running good
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Re: TBI intake manifold - need bolt torque
    anyone know what to torque intake manifold bolts to? chiltons is a piece of crap
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    35 pounds
    and the back two passages are surpose to be blocked.
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    yeah i figureed that about the passages, my new gaskets had them block too, so i just put them on. Also found the torque specs in the manual they were just really hidden. Thanks though, hopefully everything will go back right, and i wont fall asleep doing it.
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    finally got it together...need to tim it, but will do tomorrow...er later today i guess..it actually runs!!!!!!!!!!
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Well, that accomplished nothing. Still running like crap, actually even worse lately...the map sensor isnt bad, borrowed one off a friends truck and it did the same thing. Running out of ideas here
  8. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    Not sure what you mean by "runnig like crap"
    Idle, cruise, accelertion..??
    Idle, bad temp sensor--O2 sensor--TPSensor..Leaking egr..bad injector nozzle
    Everywhere...bad wires...plugged cat...bad injector nozzle
    Did anyone check for codes..."might" be enlightening..
    /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
  9. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    I hate chiltons, they dont have any specs and anything to hard to explain they tell you to seek a professional.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  10. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    sorry about that, it was in another post...basically surging when hot and at lower rpms...not when cold though
    rebuilding the TC tomorrow since i tried cleaning the injectors today and its leaking...injectors spray better though
