TBI Issues...
Discussion in 'The Garage' started by Poohbair, Feb 15, 2006.
  1. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    TBI 350 in a friends truck. Throttle feels very sticky when the engine is running. Replaced throttle cable, and it is still crappy. The throttle feels fine when the engine is off... but as soon as you start the truck the throttle sticks and the TBI wont shut all the way.
    Any ideas why this would be any different w/ the engine running than with it off?
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    How is the IAC valve looking? It might be sticking instead of the throttle cable...
    If not the IAC, is the cruise control on the fritz and pulling the throttle part way open for some reason?
  3. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    there is no cruise. IAC could be on the fritz..... that would make sense why it only does it with it running.... i never tried it with only the key in the on position... if that would matter.
  4. dyeager535
    26,982
    191
    IAC doesn't move the throttle plates themselves...if no cruise, I can't think of why the throttle plate would be sticking open only when it was running. I'd try disconnecting the throttle cable and working the TBI with the engine running see if it is replicated with the cable out of the picture.
    Having a hand on it (with no leverage) might show another problem.
  5. chevyk2500hd
    chevyk2500hd 1/2 ton status
    Nov 24, 2005
    192
    Lafayette, Indiana
    The butterfly may be hitting the wall of the tbi. I had to file slightly on my holley's. I got mine out of wack when I was beating on the shaft of the tbi.
  6. Russell
    Jun 23, 2000
    7,925
    337
    Wasn't thinking so much about the IAC moving plates, so much as it messing with the idle and making him link the plates are sticking open, even if they arn't.
    I can't think of any reason at all why a throttle body's throttle would stick while running, but not while it isn't running...
  7. dyeager535
    26,982
    191
    Yeah, I gathered by "throttle feels sticky", that the cable was swapped out, and "throttle feels fine when the engine is off" that it was pretty well narrowed down to something mechanical not related to electrical stuff.
    I see where you are coming from though. :)
