Tbi manifold choice?
Discussion in 'The Injection Section' started by camok5, Jan 25, 2007.
  1. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    So I have pre 86 (383 stroker) engine that I'm building to replace my tired stock 87 tbi engine. I have run into a few problems being that the new engine is a pre 87. One problem is that I want to run a good tbi aluminum manifold but I guess you have to modify 4 bolt holes to make it work on the older heads plus I'm running a larger 1-13/16 bored out tbi. The edelbrock performer tbi manifold only comes with 1-11/16 bore. The holley projection comes with the larger 2'' bore but you have to use an older egr plus modify the bolt holes. I could go with a carb manifold and run a adapter plate which fixes the bolt hole problem but then how does everthing else bolt up and do I still have to use an older egr? Why cant they just make a manifold that works with the older heads and comes with the larger 2'' bore?:mad:
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Both the bolt hole issue and the bore diameter are both easily fixed.
  3. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    I used a GM 454 TB plate that accepts a quadrajet pattern intake.
  4. Bushwhacker
    Bushwhacker 1/2 ton status GMOTM Winner
    May 13, 2002
    796
    Indian Trail,North Carolina
    x2,
    did this when I built my roller motor, not a big issue. worked great.
    Clay
