Tbi manifolds
Discussion in 'The Injection Section' started by jamber2541, Aug 5, 2006.
  1. jamber2541
    jamber2541 1/2 ton status
    Apr 10, 2006
    424
    e.p. texas
    Is there a difference between the 87-89 intake manifolds and the 90-91 intake manifolds on K5 small blocks:confused: I want to add a Holley TBI and want to know the difference between the 502-6 and 502-9 part numbers.
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    more than likly just has a.i.r. ports or non a.i.r. ports in manifolds.
  3. dyeager535
    26,975
    He's talking intake, not exhaust. :)
    Maybe there was a change in how the EGR valve mounted?
  4. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    I believe the difference is in the IAC and/or TPS used on the throttle bodies. I think the connectors on each sensor changed in 90....
  5. jamber2541
    Apr 10, 2006
    424
    e.p. texas
    The reason I asked is because I have a 90 and it has the connectors for the 87 to 89 models. That answers that, what size are the throttle bores supposed to be?
  6. sweetk30
    Nov 1, 2004
    25,526
    526
  7. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    stock bore size should be 1-11/16"
    Both the holley and the 454TBI should be 2"
  8. jamber2541
    Apr 10, 2006
    424
    e.p. texas
    thank you all for the info
