tbi motor problems
Discussion in '1983-2005 S-Series models' started by Nrose07, Jan 23, 2002.
  1. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    Friends 95' S-10 2WD Vortec TBI 4.3 The problem is magically overnight it started running like [censored]. Cranks, fires, but seems to run on only4-5 cylinders. So I've checked everything, fixed a few problems on the way but still hasen't fixed it. New plugs, fuel filter, gas, plug wires, coil, air filter, cap/rotor. I can drive it ok if I drag the brakes and keep on the gas. It runs ok with throttle and a load, but not at a idle. Got spark, got fuel and its smooth on the road. Engine code 32 is coming up, EGR system. Need some input, Thanks Guys!
    Displacement, cubes, and did you say you drive a riceburner???
  2. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
    Your best bet would be to check the vacuum lines. My old Monte Carlo did that and that was what it was. Friggin GM used some cheap-ass tie wrap on the line and it cut through it. After I replaced it, it ran fine.
    <a target="_blank" href=http://www4.ncsu.edu/~brschoch>www4.ncsu.edu/~brschoch</a>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The computer already told you what to check. An EGR valve that is sticking in the open position will cause the symptoms that you're describing. [​IMG]
  4. Jamus
    Jamus Registered Member
    Jan 10, 2002
    29
    Morgantown, WV
    Most definitely a clogged EGR. Mine did the same thing. I have the CPI engine with an all electronic EGR, $160. I'm cheap so I just made a block-off plate for it. The vacuum type of EGR is less expensive. Plus, if you choose, you could disconnect it by putting a screw in the vacuum line.
    94 Blazer, 4.3 cpi, 3" body lift, SFA with dana 30/Ford 9", 33's
