TBI newb-no start **SOLVED**
Discussion in 'The Injection Section' started by mrk5, Aug 23, 2006.
  1. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    Okay I'm an old carburetor die hard that's entering the 21st century. I picked up an '88 K5 and I'm planning to swap the TBI onto my '84.
    The '88 hasn't been started since 6-8 months ago. I want to make sure it runs good before I swap everything onto the '84.
    So onto the meat of the problem, it won't start.
    My guess is fuel pump. The truck cranks fine and if we pour little fuel in the throttle body, it will run for the 5-10 seconds the poured in fuel supplies.
    I don't hear the pump running like I do on the TBI trucks I've been around.
    We tried jumping a wire from the positive on the battery to the little plug below the fuel pump relay while cranking the motor. Nothing changed. FWIW, we did get a spark out of the lead when contacting the terminal. I guess I really don't know what that little test lead is supposed to tell me.
    Anything else I should test before just replacing the pump? I do have spare pump from my bro-in-law, so at least I don't have to spend money.
    One other item of mention, I don't want to leave any possibility out. I don't know how much charge the battery in the truck had. I put it on a trickle charger for 8-hours. Somebody had cut the terminal clamps off the cables so we just vice gripped the bare ends on the battery along with a large gauge wire coming from the alternator. Would low battery voltage be an issue? It seemed to crank just fine.
    Sorry for the long post, but I know I hate it when others ask for trouble shooting without enough background.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    if it is cranking and you are hearing no fuel pump first check the wires to the fuel pump. If you got a spark from the lead to the fuel pump, this could be becaause the wire is grounded before the pump or the pump has a internal ground(means the pump is bad). Also you might want to check to see if the injectors are getting a signal. Using a test light it should blink while cranking and hooked up to the injectors.
  3. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    Cool, I'll try that with the injectors. Thanks!
    I was already planning to trace out the wiring.
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Hey, welcome to the wonderful world of fuel injection!!:wink1:
    Let us know how you get on. It'll be worth it in the long run......I think!
    Damn...next thing you know you'll be burning your own chips!:D
  5. ivie29
    ivie29 1/2 ton status
    Apr 26, 2006
    212
    gypsum, colorado
    I just finished putting a 327ci in my 88 k5 and when I tried to start it the injectors wouldnt fire then i realized that I forgot to hook up the wire from the battery to the back of the alternator.You said that your cables were cut off and Im willing to bet that you just need to hook a wire from the positive terminal on the battery to the small stud on the alternator.
  6. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    Yeah, my brother-in-law caught that one. The first time I tried, we didn't connect that wire. We tried it again with that wire connected and still no start without us pouring gas.
    Hopefully I'll have time to try it out again tomorrow.
  7. ivie29
    Apr 26, 2006
    212
    gypsum, colorado
    Damn I thought that was it for sure.
  8. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Here is the troubleshooting list straight out of the manual.
    1. Fuel Tank Empty
    2. Battery discharged, engine rotates slowly
    3. Battery terminal connections loose or corroded
    4. Fuel not reaching fuel injection unit. Check for clogged fuel filter, defective fuel pump, or clogged fuel tank vent lines
    5. Faulty distributor components
    6. Defective oil pressure or fuel pump switch
    7. Low cylinder compression
    8. Valve clearnces out of adjustment
    9. Water in fuel system
    10. Defective ignition coil
    11. Dirty or clogged fuel injector
    12. Wet or damaged ignition components
    13. Worn, faulty, or incorrectly gapped spark plugs
    14. Broken, loose, or disconnected wires in the starting circuit
    15. Loose distributor
    16. Broken, loose or disconnected wires at the ignition coil or faulty coil
    17. Timing chain failure or wear affecting valve timing.
  9. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    I know, I wish it was that simple. :smirk:
    James, the funny thing is I think the tank might just be bone dry. I'm going to add some fuel. Wouldn't it be funny if that is what the problem is.:rolleyes:
  10. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    A friend put his tank back into his '59 caddy. When I got there he was cranking it over with no joy at all.
    Fuel? I asked.
    Put a gallon in. he said.
    Well a gallon in the bottom of a tank that big probebly sits less than an inch deep. Put another gallon in and it fired up straight away!
  11. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    That did it, 2 gallons of gas and it fired right up and ran.
    So I'm feeling like both :doah: and :saweet:
  12. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Hee-hee, firefighter184 just earned a reprieve.
    You just made top of the HUA list. :haha: :haha: :haha: From now on you shall be my pet project and John shall help me make sure you never forget. :rotfl:
  13. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    :doah: :haha: All's well that starts well! lol.:D
  14. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    :haha: :haha:
    :o :o
    :D
    :doah:
    So the question of the day is how many CK5ers does it take to figure out ther is no fuel???????????
