TBI on 400 SBC
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by grtwhite, Mar 14, 2004.
  1. grtwhite
    grtwhite 1/2 ton status
    Aug 3, 2000
    366
    Macungie, PA
    Got some questions about swaping over from a carb to a TBI on my 400. I've got a 77' with a mostly stock 400. Running headers and going to be putting on an eldebrock intake and a mild cam. Planning on swapping parts from a 350 TBI truck and adding a throttle body from a 454. What size injectors would you guys recommend? Have a friend who can burn me custom chips so that's not a concern. Thanks for your help!! /forums/images/graemlins/thumb.gif
  2. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    I would say injectors for a 454 big block would be about right. I get about the same fuel mileage with my built 406 that our stock 454 gets in our C30.
  3. mplogic
    mplogic 1/2 ton status
    May 7, 2002
    263
    Phoenix, AZ
    What is that mileage if you don't mind me asking? I've got a SB400 using stock 350 heads and intake and my mileage didn't change much (just under 12mpg). I do need to richen up the mixture a bit though as I'm getting a "lean mixture" error code. It feels good, lots more low end than my stock 350 had, but I'm probably not getting all I could out of it (powerwise).
    I hear the Holley 350 TBIs are supposed to have a higher output injector but you want to be sure to get the delphi and not the old style as they were problematic. I thought about going to the 454 injectors too, but don't want 6mpg. /forums/images/graemlins/smile.gif
