TBI or TPI?
Discussion in 'The Garage' started by beater_k20, May 10, 2004.
  1. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    which would make a better all around truck? i have most of a TBI setup, and have access to several TPI setups, so both are pretty much "what i have" type deals. from my understanding, the TPI system would offer better distribution to all cylinders, no matter what the angle its operating at. that seems like enough advantage to me to go to a TPI setup rather than TBI. am i correct in thinking this way?
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    You will have more power and better fuel mileage with Tuned Port Injection. TPI is much more "performance" oriented and was originally on Corvettes and camaros. Because of TPI systems being fairly easy to obtain and good aftermarket multi port units available....I would never even consider TBI on a non stock motor.
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Definately TPI is a better setup, but both are good for off road use, TPI will as mentioned give you better throttle response, performance and fuel economy, as the injectors inject fuel right into the port above the valve, less area for it to travel and is more precisely metered. I had it on my '89 IROC Camaro i had and i absolutely loved that engine, i have TBI on my Burb now, and i do like it, it's dependable, but is definately not like the TPI setup, i'd go with TPI. /forums/images/graemlins/thumb.gif
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    TBI is easier to install. TPI is more involved and more work. I personally think it is worth the work though. I put TPI on my truck. I LOVE it. Worth all the time and every penny.
    TBI will be a cheaper easier install then TPI.
    Either way do your homework on the system before you try and install it. Read everything you can find on both systems and make an informed decision. If you look threw some of my posts from about October 03 - January 04 you will find alot of TPI tech.
    Thirdgen.org has alot of tech too.
    I don't think I will ever own another SBC that isn't TPI. Carbs are no longer something I would bother with now that I have had TPI. I might be inclined to use an SBC if I bought it with TBI already installed or if I got it real cheap but if I have access to both at the same price TPI is the choice for me.
    Also be aware that there are 2 different types of TPI. MAF & MAP.
    MAP is more involved them MAF.
  5. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    aftermarket is hot on the TPI system also (chips, injectors,runners,ect.) you have alot more real power options then the TBI
    thats my change on it /forums/images/graemlins/grin.gif
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    TPI is much better. I wouldnt even consider converting anyting to TBI. And, depending which setup you use, it looks alot cooler too!
  7. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    TPI all the way...chicks will throw their panties at you when they see it... [​IMG]
  8. dyeager535
    26,980
    I would say TPI, but thats only if you have the time, inclination, and parts. Either are better than carbs of course.
    As was mentioned, MAP installs are a bit more "complex" (really it's more that they aren't as "adaptable" as a MAF setup) but they are also a lot cleaner. With no MAF needed, you don't have to worry nearly as much about your induction system.
    Induction can be plumbed fairly easily, but it is still something to think about.
    MAF adapts better than MAP to a fair range of mods, but even then, to get the most out of either setup, chip burning is a "must" if it's not on the complete original setup.
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i picked up a 60 last weekend, chicks are gonna throw their panties anyways.
