TBI problems...
Discussion in 'The Garage' started by divorced, Oct 10, 2006.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    My bro has a '92 Burb with a TBI 5.7 in it. From what I remember him telling me, he can start it and it will run fine for just a few minutes and then it will idle rough and miss out and smell like it running real rich. There is also a loud squeeling noise coming from the throttle body. He can unhook the vacumm line to the map sensor and it will idle fine.
    He replaced the map sensor because of the codes, but it still won't idle right. He also replaced the cap and rotor.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    is it throwing any other codes? has he checked the IAC valve and to see if the passages might be carbon blocked, try running some seafoam through it
  3. divorced
    Jul 20, 2004
    5,115
    I'll have him check for other codes and suggest checking the IAC valve and possibly the seafoam.
  4. wetbackZO
    wetbackZO 1/2 ton status
    Jan 30, 2006
    113
    Las Cruces, NM
    make sure the Engint Coolant Temperature sensor is not disconnected/damaged...
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If you have a loud squealing from the throttle body the base gasket is prolly bad and leaking air. That will cause idle problems and the lean condition will cause the ECM to constantly richen up the mixture.
