TBI question,already searched UPDATE!
Discussion in 'The Garage' started by outlaw612, Mar 22, 2003.
  1. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I have searched on this and think I already know the answer, but need confirmation.
    Ive got a TBI setup off a 92 350 and Im wanting to put it on my 79 motor. The intake wont just bolt to the older model heads so what are my choices? I heard there was an adapter to allow to bolt the TB directly to and older intake, is this correct? If so, I have 2 questions...
    1) Where can I get this spacer/adapter?
    2) What is a good aftermarket intake to use with the TBI on an older motor?
  2. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Re: TBI question,already searched
    Holley makes both a TBI intake with a pre-87 intake face and a TBI to 4bbl adapter. Check their website for part numbers, summit, or jegs
  3. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    you can hog out the center holes with a drill bit and use/make an angled washer to take up the slack... works fine and if you are carefull it wont leak.
  4. outlaw612
    Feb 11, 2001
    2,342
    Thank for the info, thats what i wanted. /forums/images/graemlins/thumb.gif
  5. outlaw612
    Feb 11, 2001
    2,342
    I know that can be done, and since I already have the factory intake, I might try it. I just dont want to chance having and air leak around the intake like happens alot if you do it this way. The couple of people i know locally that have went to TBI on an early engine both used the stock intake and both had leaks. /forums/images/graemlins/frown.gif
  6. florida4x4
    Sep 9, 2002
    255
    Florida
    The leaks are most likely due to improper torque caused by the slop in the washers. To do it correctly you would want a machine shop to spot face the center bolt holes so you could apply proper torque. This can cost more than than sourcing and earlier manifold on ebay.
    I've yet to do this job but I have a 1991 TPI waiting for me to get time (already spotfaced)... Most guys on the efi list say leaks be stopped with the proper application of liquid duct tape (black RTV).
  7. outlaw612
    Feb 11, 2001
    2,342
    Thats interesting, I never thought of that. I just assumed the leak was from the enlarged hole rather than improper torque. Ill look into spotfacing the center holes and compare to the cost of a new aftermarket intake. Thanks for your input! /forums/images/graemlins/thumb.gif
    Id still like the part # for the adapter if anyone has it, I havent had any luck finding it.
  8. outlaw612
    Feb 11, 2001
    2,342
    I finally found the part numbers so Ill post them for everyone. These came straight from Holley Tech.
    TBI adapter for spreadbore intake...17-41
    TBI adapter for squarebore intake...17-45
