TBI QUESTION ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Frank, Jun 17, 2002.
  1. Frank
    Frank Registered Member
    Oct 2, 2001
    16
    need help please!
    I have an 87 Blazer with a 305 motor w/TBI.
    How can I tell if the the TBI is faulty?
    The engine turns but won't start. I looked into the TBI while the engine was turning over and observed fuel dripping from the injectors down to the throttle valve. Is this normal? Or are the injectors suppose to spray the fuel down the thorttle valve?
    thanks!
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    It may be the fuel pump not building enough pressure...I doubt the TBI would go bad.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    It could be the fuel pump, clogged fuel filter, bad regulator, or fuel pump relay.
    But.
    You really need to check for trouble codes. There are a number of other things that can go wrong that will tell the computer to shut off fuel. Check the trouble codes before you go replacing a bunch of expensive parts. Then find out it was just a cheap ignition part or sensor causing the problem.
