TBI question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazingboy, Mar 24, 2003.
  1. blazingboy
    blazingboy 1/2 ton status
    Dec 2, 2001
    120
    Georgia
    My truck when it is cold or hot it turns over about 5 or 6 times before it will start. Does anybody else truck do this I even tried given it some gas before starting and still doesn't help.
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    well punchin the gas before starting wont do anything with a tbi. and my truck turns probably 3-5 times before starting, always has.
  3. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Same here, my 88 turns over 5-6 times before it starts.
    My carburated 71 Elky kicks over on first turn /forums/images/graemlins/ears.gif
  4. Miller
    Miller Registered Member
    Mar 21, 2003
    56
    Mtn Home Idaho
    mine starts with 3 or so cranks, but when the winter temps drop below -10 then it takes few extra turns and slugish half idle start.
  5. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    When hot my 88 fires up instantly. cold it cranks a couple times.
  6. dyeager535
    26,980
    Do you give it 2 seconds after turning the key to the "run" (not start) position?
    The fuel lines have to pressurize if it's been sitting (and probably very much temp dependent) so you have to wait for the fuel pump to pressurize the system if you want quick starts.
