TBI Questions
Discussion in 'The Garage' started by paintyouup123, May 1, 2006.
  1. paintyouup123
    paintyouup123 Registered Member
    May 31, 2005
    14
    California
    I have a 5.7L in my 89 sub and I was wondering if you put in a 1 in tbi spacer do you have to get fuel line extensions or is it not necessary. also i was wondering what size are the three bolts that bolt the tbi to the manifold. Thanks
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    If you undo the securing bracket at the back of the block you'll probebly be able to pull the lines up enough but check for them chaffing on the chassis etc
  3. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I put a spacer on mine and did not have to lengthen the lines. There was plenty of slack to fit.
  4. Tabb
    Tabb ROLL TIDE! AGAIN! GMOTM Winner
    May 2, 2006
    3,566
    21
    Heart of Dixie
    how much of a differance has that TBI spacer made on your engine?
  5. WhiteBurb
    Mar 10, 2005
    307
    Louisiana
    I noticed a bit more power at low rpm, mostly when taking off from a stop. It wasn't a big increase, but I think it was worth it. And it makes a cool whistling noise too.
  6. sarasotausmc
    sarasotausmc 1/2 ton status GMOTM Winner
    Dec 16, 2003
    769
    Jacksonville NC
    I put a CFM spacer in mine, and even though the gas pedal stuck a little, I ran it for about 300 miles. Guess I didn't really notice much of a difference until I took it back off. Everything except the acc. cable fit just fine. I don't remember what size the bolts are, 3/8" is coming to my mind though.
  7. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    i put one on my 94 c1500, about 5 years ago and i was able to pull the lines up to fit, no problem. i wouldn't expect it to be much worse on the blazer. i got a modest low-end improvement, a little better mpg, and can cruise on the highway at slightly lower rpms than before. worth the small amount of time and effort, imo.
  8. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    I'm curious how a TBI spacer apparently alters the overall gear ratio of a truck, which is would have to do in order to let you cruise (at the same speed, I assume), at lower RPM.
  9. vortec
    Jul 22, 2004
    1,472
    fort worth, texas
    gear ratio isn't the only way to affect something like that. could mean a lot of things. maybe the powerband flattened a little. maybe it shifted so that i make my power at lower rpms than before and peak out sooner. i've seen peoples' rpms change because of all sorts of things, with no gearing change. changes to cams, intakes, exhaust, forced induction, etc. can affect that. when my friend put a smaller supercharger pulley on his gtp, he got a similar, but more significant result.
  10. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    I assume that your '94 has either an auto with a lockup TC or else a manual trans. Unless you changed the gear ratio (or tire diameter) in some way, the engine's revolutions per minute shouldn't change unless the crusing speed in mph changes.
    Do you mean throttle position instead of engine RPMs?
  11. sarasotausmc
    Dec 16, 2003
    769
    Jacksonville NC
  12. vortec
    Jul 22, 2004
    1,472
    fort worth, texas
    tranny is a 4l60e. i'm no expert, but i'll put it this way, if an engine's power is increased, it should be able to overcome the same amount of resistance (friction, gravity, air resistance, etc.) with less effort. but i'm just going by what i've observed. i don't have any fancy numbers to prove it. dang. of course, new mods always come with a free right foot upgrade. :grin:
