TBI? Replace injectors or upgrade whole Unit ?
Discussion in 'The Garage' started by Mudbug1979, Jun 27, 2004.
  1. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    Got two injectors that need to be replaced. Wondering if it will benefit me any to find a 454Tbi or use the Holley 670cfm unit. Anyone ugraded and thought it was worth it? The stock unit is like 400cfm or something isn't it? Mild 350, th350, 36"s, 4:10's, Dual 2.5" exhaust, no headers. /forums/images/graemlins/ears.gif /forums/images/graemlins/1zhelp.gif
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I'm not positive but I think even if you buy the Holley TBI you still need to reuse your old injectors.
  3. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Why don't you adapt a 454 TBI. You may have to use the 350 injectors or else you may run to rich. My set up is assbackwards because i'm running 454 injectors in a 350 TBI on my 388 stroker at the angle sector 45 kilometers south south west 243 degrees northern.
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Not to hijack this post or anything but is the 454 TBI a direct bolt-on or is there an adapter needed? I just cleaned a TBI 454 intake at work the other day for a guy and it looked like it was meant for a quad but it said TBI on it and I ask the guy and he said it was from a 88 454 TBI.
  5. Mudbug1979
    Aug 4, 2002
    439
    Good question? Is it a direct replacement or will I need an adapter. I miss the power that my Carb had but don't want to get rid of the usefullness of the TBI. I NEED MORE POWER !!! /forums/images/graemlins/peace.gif
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The factory 454 TBI's came with a QuadraJet intake, with a cast aluminum adapter that fit between it and the throttle body.
    The bores are larger on a 454 TBI than on a 350 TBI so you either need to have the 350 intake bored out a bit or build a custom adapter, to clear the throttle blades.
  7. Mudbug1979
    Aug 4, 2002
    439
    Will a set of 454 Injectors work on a 350 TBI unit? I realize that it will just be adding more fuel and no air to compensate. OR, is there a better set of injectors that I can put on there, like one's from a 9C1 cop car?
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I'm pretty sure that the injectors are physically interchangeable. But once you do that then you must reprogram the computer. Truck 350 TBI injectors flow 61 lbs/hr, while the 454 injectors flow MUCH more than that. If you could even get the engine to start with the bigger injectors it would run WAY rich. The computer has to know the flow rate of the injectors to help it calculate the proper flow for any particular condition.
  9. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Yes the 454 injectors will fit in the 350TBI pod but they are WAY too bug unless your engine in modded to the hilt with a custom chip. IIRC, 454 injectors flow 82#/hr of fuel...
    Chris
  10. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Cool, thats kinda what i thought. I am just gathering parts for my 383 i am planning to build later this year and i will need more fuel and air to go along with the bigger cubes. I will have a chip burnt accordingly. /forums/images/graemlins/thumb.gif
  11. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    I am running a 350 TBI with 454 injectors in my 388 stroker. It ran very lean with the stock ones, and it runs stoich/lean now with the bigger injectors. At WOT it is not rich like it should be, but at stoich. It just puts out a little more volume so the computer can actually attempt to compensate for the larger displacement. What I really need is an adjustable fuel pressure regulator to make finer adjustments.
    Oh, I knew the A/F ratio via an A/F guage.
