TBI spacer - pro & cons
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Scott73, Jul 22, 2002.
  1. Scott73
    Scott73 Registered Member
    May 22, 2002
    38
    Electra, TX
    I've heard people talk about TBI spacer. Is a good or bad idea. I have an 87 K5 w/ a 350. What are the pros and cons of a spacer?
  2. Wally81k5
    Wally81k5 1/2 ton status
    Jul 14, 2002
    139
    Cold Lake Alberta
    Hey, I have one on my 1990 GMC 350 TBI. I don't know how much of a difference they really make, if you could machine your own or build one from phenelic then I would do it, but to me it wasn't worth the 1-2 hp.
  3. blazen_md
    blazen_md 1/2 ton status
    Aug 20, 2001
    129
    MD
    I have a 90 k5 with a 350 tbi and I used the air raid tbi spacer and it gave me better throttle response and maybe a little better gas mileage. Just if you do get one be sure that your kickdown cable gets adjusted right. But every little bit helps I guess.
  4. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    I, too have one and would concur that the difference is only slight. I used to have better performance by flipping my factory air-cleaner lid (which I can no longer do because of the added height).
    If you have an auto tranny I'd guess the install would be a little more difficult but in my case the throttle cable (although far from striaght) connected fine.
