TBI spacer = TV adjust?
Discussion in 'The Garage' started by tuner-automotive, May 21, 2005.
  1. tuner-automotive
    tuner-automotive Registered Member
    May 7, 2005
    74
    oregon
    I have a 90 GMC Jimmy k1500 w/350 TBI.
    Last night I installed my phenolic TBI spacer 1".
    I noticed it was alittle tight getting bolth the Accel cable and the TV cable to slip back on .
    Has anybody else installed these on there TBI's and if so did you have to readjust the TV cable?
    Im pretty sure I will have to lengthen the accel cable as Im haveing alittle trouble getting the butterflies to close once at idle.
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yeah definaitly. I made up a different bracket in the end to sort out the throttle pull. Re-adjust your tv to be safe. Only takes a second and could save $$$$!!!
  3. tuner-automotive
    May 7, 2005
    74
    oregon
    The guy I go see that runs a tranny shop told me how to adjust the TV .
    Push a button on the side of the TV cable and then pull the cable towards the frt of the vehicle as far as I can.
    Then go inside and mash the throttle .
    Said it should click into the correct position.
    Sound about right?
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    You release the button then pull the throttle arm on the TBI fully open then release the tab. Don't do it by pressing down on the throttle pedal as you may not be getting true WOT. have a read of tv article 101 at www.tvmadeez.com . It's informative and tells why and how it should be done. :)
  5. twb1997
    twb1997 Newbie
    Oct 23, 2009
    3
    Oregon
    I can't seem to find the button to push so I can adjust the cable. I feel like a moron. Please help. Also is it possible to adjust the throttle cable?
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
  7. twb1997
    twb1997 Newbie
    Oct 23, 2009
    3
    Oregon
    I have crawled all over this thing and not found the stupid button. I will go back out in the morning and see if I can find it. I have read the link provided several times with no luck. Also how do I adjust the throttle cable. With it in the bracket it revs at 3000 rpms and the valves on the TBI are open. This problem has me stumped and I considered myself at least somewhat intelligent about motors.
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    if you installed a spacer under the carb/tbi, that is your problem... you need to run the 2 1" spacers under the bracket that come with better spacers.. my CFM tech one did..
    try looking at the tv cable from the passenger side... right behind the bracket where it clicks in, is a flat section, but the whole area is shaped like a D, thats it.. on the dizzy side of the bracket...
    you may not be able to set it, if the geometry is wrong.. meaning the bracket doesn't have the spacers..
  9. pierce88K5
    pierce88K5 1/2 ton status Premium Member
    Jan 11, 2005
    134
    Malvern, AR
    On my 88 K5 the "D" button is on the Drivers side of the TV adjust, not the dizzy side. Maybe you are looking on the wrong side?
  10. twb1997
    twb1997 Newbie
    Oct 23, 2009
    3
    Oregon
    I will check it all over in the morning, but I have looked on both sides. I must be blind. lol
  11. Jasonglh
    Jasonglh Registered Member
    Sep 7, 2009
    31
    Kentucky
    The Turbo City spacer is only 1/2" thick while the CFM is 1" thick but whats the bottom line difference in performance between them?
