TBI starting problems?
Discussion in 'The Garage' started by Rockjunkies, Nov 24, 2002.
  1. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    I put a chevy tbi motor in my rig and finally got it wired in using a painless wiring harness. We did not use the vss or egr valve. The injectors will not pulse while the engine cranks over. You can start it by priming the tbi and it runs great afterwards. There is no codes stored in the computer. Any body have any sugestions on what could be causing this!
  2. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    If it's a factory TBI and factory chip, you WILL through the CEL (Check Engine Light).
    I am not sure, but I think you need a VSS unit. Do you have one hooked up?
    The pump should turn on for a second or two when you first turn on the ignition. If that's not working check the three (or four) 12 volt ignition inputs.
    Check out DIY-EFI.org for more help.
    What computer (e.g. 1227747) do you have?
    Good luck.
  3. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    The computer doesn't have the power hooked up right. Don't know about the painless loom - but if you look in a factory wiring diagram there are a few different power feeds into the computer. Its one of them thats not wired right. Probably.
  4. Rockjunkies
    Jul 26, 2001
    385
    Oklahoma
    I fixed the problem. It turned out to be a faulty ign. switch. It will only start if you barely turn the tumbler. Needs adjustment. It's alway's the overlooked things! Thanks.
  5. azblazor
    May 5, 2001
    1,953
