TBI studder at part throttle when cold? Fix it!
Discussion in 'The Garage' started by y5mgisi, Aug 10, 2003.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    If your TBI motor acted like mine, where it would kinda studder in the morning backing out of the driveway,(i know im not the only one) Simply unplug the vacume line that goes down to the EGR and unplug it and cap it off. Since i have done this about two weeks ago, It has not studdered one time /forums/images/graemlins/smile.gif I know that this same thing was happening on my uncles burb when he had it so i know some of yall out there will benifet from this low buck fix. /forums/images/graemlins/thumb.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    or you could replace the EGR that took a crap and is now inactive and will cause you to fail emissions if you have it.
  3. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    You can get away with it on a carburated truck, but not the tbi. I did the same thing and it ends up screwing up the map sensor. The truck will eventually run so rich that it will not start.
  4. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Ok, so its not such a good idea, you could however do this to see if it is bad at least.
  5. Highjaxx
    Highjaxx 1/2 ton status
    Apr 17, 2002
    273
    Austin,Texas
    Mine runs really rich and stutters. Everything is pluged in too. I'm probley going to have someone hook it up to a computer and read everything. I'm hoping I can get a chip burned to help it run better.Was told the engine came out of a '92 but the computer in the truck says '91 on it. /forums/images/graemlins/confused.gif
    I don't know anything engines besides I wanted a BIG ONE, and fuel injected. If anyone knows what could be messing it up, that would help. /forums/images/graemlins/thumb.gif
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    what is it a 350? hooking a computer to it won't do crap there its not OBDII. paper clip is the only diagnostic tool. Are you sure its getting too much fuel? No offense but if you don't know engines how did you diagnose that?
