TBI Suging at idle when wet
Discussion in 'The Garage' started by kwissman, Oct 15, 2006.
  1. kwissman
    kwissman 1/2 ton status
    Jan 14, 2006
    118
    Austin, TX
    My TBI engine in my 91 K5surges if I get it wet. It runs fine at higher rpms and will go away after a drive at speed. This seems to only happen when I get in water or sloppy mud. I thought it was the stock air cleaner sucking in a little water, but it happens at the car wash also. Any ideas where to look. It is kind of dangerous on the trail as it surges enough to try to move when you have the brakes on in the trail line.
    The engine is a stock 91 with headers and a heated 3 wire 02 sensor. It only does it at idle in park or gear. Seems to run fine if I have the accelerator opened up.
    Any ideas and help would be appreciated.
    Kent
  2. K5dreamer
    K5dreamer 1/2 ton status
    Mar 14, 2005
    3,084
    Alexandria, Va
    could be a broken connector letting water in and causing electrical shorts.
    could be lots of things actually, hydrolock, yadda yadda.
    first things first, run the truck for codes. you can do it yourself with a paperclip or go to the dealership.
    if you dont know how to use a paperclip to flash codes, please ask and ill be happy to give directions.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Mine was surging and found out it was the TPS. It finally threw a TPS low voltage code. I swapped it out and no more surging. Your weatherpack connector for the TPS could be letting water get in a mess with the signal it is sending to the ECM therefore your surging.
    Ira
  4. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    check tps voltage at idle (truck need not be running, but key-on, engine off) when the throttle is closed, you should have about ..6-.8 volts, and with the throttle wide open you should have about 4.7-5.0 volts...
  5. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    If it was hydrolock, his engine ingested water, and probably has a broken connecting rod or two...and that means it probably wouldn't run at all.
  6. kwissman
    Jan 14, 2006
    118
    Austin, TX
    It is not hydrolocked. I can just drive through a water hole and it starts acting up. I will scan for codes and check the TPS. The check engine light is not on and it clears up after a 15 to 20 minute drive. Something must be getting wet and causing an intermittent short.
  7. K5dreamer
    Mar 14, 2005
    3,084
    Alexandria, Va
    the hydrolock was a bad choice of words, i was just saying there could be several causes,
    also, even without a check engine light there may be codes stored in memory, so its still worth checking.
  8. kwissman
    Jan 14, 2006
    118
    Austin, TX
    I checked the codes and came up with 42.
    The code means "The EST signal did not change when the ECM applied bypass voltage to the ignition module.".
    I checked the wires and did not see any cracks etc. Is Spark Control Module bad. They are about a $100, so I would like to make sure before I buy one.
    Is there a performance part for this or is it just the standard replacement available.
    Kent
  9. K5dreamer
    Mar 14, 2005
    3,084
    Alexandria, Va
    bingo, i had completely forgotten, both my RS and my IROC had that throttle surge, put on a new ignition module in the distributor, and it solved the problem. the cost is way high though, mine was only like 50 bucks, check out www.gmpartsdirect.com
  10. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    moisture and ignition trouble =
    My first thought was "spark plug wires"..the #1 cause of poor engine performance on damp days or while raining..especially if it improves after being driven some,and they "dry out"...the distributor cap and rotor also can cause the same thing too,or a coil that's got a crack in it....sounds more like secondary ignition trouble to me,than a fuel or computer problem,but I don't know much about them--I suppose they could act up only when damp out too??...:crazy:
